Home » Language IDEs » ServerTools (WTP) » Deployment on JOnAS server does not work
Deployment on JOnAS server does not work [message #121497] Sun, 17 July 2005 06:00 Go to next message
eclipse starts the server -- ok. But when I try to deploy a web module, I
get an error. eclipse tries to create the war in a wrong place. I have
properly set up jonas_root, jonas_base and the classpath. What do I miss in
my configuration? The variable module.name in jonas.xml does not seem to be
properly initialized.
Here the error message:
Buildfile: /opt/eclipse/eclipse_3_1_0/eclipse/plugins/org.eclipse.jst.s erver.generic.serverdefinitions_0.7.0/buildfiles/jonas.xml
deploy.j2ee.web:
      [jar] Building
jar: /opt/eclipse/eclipse_3_1_0/eclipse/plugins/org.eclipse.jst.s erver.generic.serverdefinitions_0.7.0/buildfiles/GAS_WEB.war
BUILD FAILED
/opt/eclipse/eclipse_3_1_0/eclipse/plugins/org.eclipse.jst.s erver.generic.serverdefinitions_0.7.0/buildfiles/jonas.xml:3 :
Problem creating
(Permission denied) (and the archive is probably corrupt but I could not
delete it)
Total time: 1 second
Thanks in advance,
Andreas Schenk
Re: Deployment on JOnAS server does not work [message #124351 is a reply to message #121497] Thu, 21 July 2005 19:07 Go to previous messageGo to next message
Please open bug reports for problems like these.
bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20Tools& component=jst.server
- Nitin
Re: Deployment on JOnAS server does not work [message #124815 is a reply to message #121497] Fri, 22 July 2005 11:11 Go to previous messageGo to next message
Originally posted by: gercan.removeThis.acm.org
Adreas, we have updated the build.xml' s to fully support jonas
deployments. Please check this on a recent build, if you still see this
behavior please open a bug report.
dr.andreas.schenk@gmx.net wrote:
> deploy.j2ee.web:
> [jar] Building
> BUILD FAILED
> Problem creating
> delete it)
> Thanks in advance,
> Andreas Schenk
Re: Deployment on JOnAS server does not work [message #124860 is a reply to message #121497] Fri, 22 July 2005 12:09 Go to previous message
Excuse me, How do you deploy a web module?
I am trying to do the same with tomcat, but I don't know how to create a
module and how to do the deploy.
Thanks in advance
Previous Topic:XML Schema validation
Next Topic:What is an ArtifactEdit? and how it relates to an EditModel?
Current Time: Sun Aug 31 21:02:47 EDT 2025
Powered by FUDForum. Page generated in 0.04517 seconds
