Home » Language IDEs » C / C++ IDE (CDT) » Indexing problems
Indexing problems [message #121493] Thu, 23 September 2004 12:27 Go to next message
I encounter some problems with navigation with C++ Project -
When I select a function and press F3 (Open declaration) I get an error
saying:
The operation is unavailable on the current selection" and
the navigation fails.
I tried to see what is the problem and I found myself a little confused
with the C++ indexser.
I hope you'll be able to help me...
I have these questions:
1. I get many Indexer Problems, even though in the Discovered Paths
container (in the C/C++ Include Paths & Symbols project property page) I
can see all the relevant includes were found !
Here are some of the errors:
C/C++ Indexer Problem: Attempt to use symbol failed : _prm in file:
/view/gmilman_myView_view/mvobs/INFRA/code/adt/inc/args.h
C/C++ Indexer Problem: Preprocessor Conditionals unbalanced : endif in
file: /view/gmilman_myView_view/mvobs/INFRA/code/adt/inc/baseid.h
C/C++ Indexer Problem: Attempt to use symbol failed : ostream in file:
/view/gmilman_myView_view/mvobs/INFRA/code/adt/inc/buffer.h
2. Why I got semantic or syntactic errors when the project was
successfully compiled?
3. I have some questions regarding the C++ Include Paths & Symbols project
property page:
a. I selected the Discovery paths->include sub folder, pressed on the 'add
Folder/File...' option and selected a folder. I saw the folder in the
Include paths and Preprocessor Symbols list, under the project name.
After pressing OK and reopening the Properties Dialog I saw that the
folder I added was vanished !
(The same behavior occurred when I didn't select anything in the Include
paths and Preprocessor Symbols list and selected the 'add Folder/File...'
option).Is it supposed to be like that or is it a bug?
What does the 'add Folder/File...' option suppose to do?
b. What does the 'Add Contributed...' option,suppose to do? It also
doesn't work for me ...
4.Does the C/C++ make project option have anything to do with the indexer
(John told me I need to change the Discovery options to enable
5. The 'Path Containers' in the C/C++ Project paths can have different
paths from the paths that are mentioned in the C/C++ Include paths &
Symbols option. Are these path relevant to the indexer? Why can they be
different?
Thabks a lot
Guy
Re: Indexing problems [message #121546 is a reply to message #121493] Fri, 24 September 2004 09:47 Go to previous messageGo to next message
Originally posted by: levay.all.hu
I encountered the same problems and did not have the time to go and
solve it, so now I am back to emacs now.
My project is not managed, I have my own makefile which is not called
makefile and I am using the mingw compiler installed with dev-cpp
Akos
Guy wrote:
> saying:
> property page:
> different?
> Thabks a lot
> Guy
Re: Indexing problems [message #121583 is a reply to message #121493] Fri, 24 September 2004 12:13 Go to previous messageGo to next message
If your compiler accepts it and the CDT Parser has a problem with it, please
raise a defect w/a
code example @ bugs.eclipse.org.
JC
"Guy" <guy.Milman@comverse.com> wrote in message
news:ciuti9$qcu$1@eclipse.org...
> saying:
> property page:
> different?
> Thabks a lot
> Guy
Re: Indexing problems [message #121596 is a reply to message #121493] Fri, 24 September 2004 13:48 Go to previous messageGo to next message
I noticed in a previous post that you're doing ssh to build your project.
If the include paths discovered by Scanner Discovery are not valid on your
system (i.e. make uses a directory not available on your local machine) then
you are unfortunately out of luck w/this feature.
We need the include files in order to properly parse your source code.
JC
> saying:
> property page:
> different?
> Thabks a lot
> Guy
Re: Indexing problems [message #121716 is a reply to message #121596] Mon, 27 September 2004 03:32 Go to previous message
Hi John,
Thank you for your answer.
I tried in the past to build my project with remote compilation, but the
remote navigation failed. Now I have the severe problem that locale
navigation fails too, even though the include paths discovered by Scanner
Discovery are valid on my system !
What do you think I should do?
> JC
> > Hi,
> > saying:
> > property page:
> > different?
> > Thabks a lot
> > Guy
Previous Topic:Using templates in CDT/Linux/g++
Next Topic:how to cdt like ms vc?
Current Time: Fri Nov 07 14:52:17 EST 2025
Powered by FUDForum. Page generated in 0.03659 seconds
