Home » Eclipse Projects » Equinox » Bootclasspath extension not available, alternative?
Bootclasspath extension not available, alternative? [message #121438] Mon, 24 November 2008 03:26 Go to next message
I'm using an api (StAX) whos interfaces are part of java6 but not 5. I
wish to support both versions (need to run on mac) and thus include the
interfaces. I tried solving it using the fragment-host extension
bootclasspath, but it does not seem to be available on mac os x.
What is the alternative..? If I include the interfaces as a regular
plugin they collide with the jdk provided ones..
Ulf Holm Nielsen
Re: Bootclasspath extension not available, alternative? [message #125359 is a reply to message #121438] Sun, 01 February 2009 09:19 Go to previous message
Originally posted by: sameera.wso2.com
AFAIK, The best solution would be to version javax.xml.stream.*
packages. Then you need to import the correct version in all the bundles
which use the javax.xml.stream.* packages.
Sameera
Ulf H Nielsen wrote:
> Best regards,
> Ulf Holm Nielsen
Previous Topic:multithreaded safety of equinox
Next Topic:[p2] updating a configuration wich has missing dependencies
Current Time: Tue Nov 04 03:43:03 EST 2025
Powered by FUDForum. Page generated in 0.04484 seconds
