Home » Modeling » BPEL Designer » The import org.eclipse.bpel cannot be resolved
The import org.eclipse.bpel cannot be resolved [message #11109] Wed, 27 August 2008 06:10 Go to next message
Originally posted by: soeren.dupke.gmx.de
i am trying to use the BPELReader inside a plugin. I added a dependency
to org.eclipse.bpel.model. Now I have the problem with the unresolved
import. Did I forget something?
Sören
Re: The import org.eclipse.bpel cannot be resolved [message #11300 is a reply to message #11109] Tue, 16 December 2008 07:57 Go to previous messageGo to next message
I have same problem... Any help?
Miroslav
Re: The import org.eclipse.bpel cannot be resolved [message #514495 is a reply to message #11300] Mon, 15 February 2010 10:31 Go to previous messageGo to next message
Same problem and still without a solution,
Any new help?
Re: The import org.eclipse.bpel cannot be resolved [message #515735 is a reply to message #514495] Fri, 19 February 2010 21:40 Go to previous message
what are the unresolved import?
BTW, you can take a look on the pluing.xml in the org.eclipse.bpel.model plugin. Maybe you can get the reason.
Previous Topic:Newer in creating a bpel process
Next Topic:Create BPEL project from the BPEL package
Current Time: Sat Jul 26 04:28:49 EDT 2025
Powered by FUDForum. Page generated in 0.03948 seconds
