Home » Language IDEs » ServerTools (WTP) » WSDL File save changes format
WSDL File save changes format [message #121339] Fri, 15 July 2005 18:24 Go to next message
Originally posted by: michael.giroux.objectweb.org
Using Eclipse 3.1, + WTP 0.7RC 1 And all prerequisites.
When editing a WSDL w/ wsdl editor, the Source->format menu does a nice job
of formatting the source. Unfortunately, as soon as I File->save, the
format is messed up.
Has anyone else seen this?
Michael Giroux
Re: WSDL File save changes format [message #121458 is a reply to message #121339] Sun, 17 July 2005 02:25 Go to previous messageGo to next message
Hi Michael,
I just checked out your claim and it does seem to be doing that. Please
open a bug against the Web Tools -> wst.wsdl component so this can be
addressed.
Thanks for reporting.
Lawrence
job
>Michael Giroux
Re: WSDL File save changes format [message #121816 is a reply to message #121458] Mon, 18 July 2005 10:55 Go to previous messageGo to next message
Thanks for confirming the problem.
Bug filed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104223
Michael
<lmandel@ca.ibm.com> wrote in message news:dbctlg$5ig$3@news.eclipse.org...
> Hi Michael,
> addressed.
> Lawrence
> job
>>Michael Giroux
Re: WSDL File save changes format [message #121841 is a reply to message #121339] Mon, 18 July 2005 11:38 Go to previous messageGo to next message
I've discovered a work-around until a fix is available -- do the save from
Text Editor.
You need to keep the file open in two editors (thanks Eclipse 3.1) wsdl
editor and text editor. Make changes in the wsdl editor, and do saves from
the text editor.
Michael
"Michael Giroux" <michael.giroux@objectweb.org> wrote in message
news:db9d3h$d7q$1@news.eclipse.org...
> job of formatting the source. Unfortunately, as soon as I File->save, the
> Michael Giroux
Re: WSDL File save changes format [message #123920 is a reply to message #121841] Thu, 21 July 2005 03:28 Go to previous messageGo to next message
Michael, if you look in the preferences, under Web and XML -> WSDL you can
uncheck an option to 'generate bindings on save'. This might help you
workaround your problem. Hopefully we'll have a better fix for this soon.
Re: WSDL File save changes format [message #124120 is a reply to message #123920] Thu, 21 July 2005 13:36 Go to previous message
Thanks Craig. That solved the problem for now. Not sure if there are
side-effects but for now it is a good workaround.
Michael
Previous Topic:bugs in TextHoverManager
Next Topic:ArtifactEdit question
Current Time: Thu Jul 17 03:02:24 EDT 2025
Powered by FUDForum. Page generated in 0.26866 seconds
