Home » Archived » Test and Performance Tools Platform (TPTP) » JVM Segfualt When Profiler Started
| JVM Segfualt When Profiler Started [message #121329] |
Thu, 24 January 2008 06:50  |
--------------030509080906000307090005
Upfront warning, I'm a complete TPTP newbie.
I am attempting to profile a web application on a remote server. The
remote environment is a 32bit CentOS 5 box running Sun Java
1.5.0_12-b04. I'm using the TPTP 4.4.0.0 (as reported by ACServer)
Agent and the controller is starting fine. Tomcat is being started with
the following JVM flags "-server -Xms128m -Xmx512m -XX:MaxPermSize=256m
-XX:ThreadStackSize=256 -XX:+DisableExplicitGC
-agentlib:JPIBootLoader=JPIAgent;CGProf:execdetails=true".
Now, I connect to the server from my laptop (OS X 10.5, Apple Java 1.5,
Eclipse 3.3.1.1, TPTP 4.4.1) and it correctly finds the execution
analysis profiler running there. So, I begin a profiling session. At
this point I could hit my web application and everything work fine.
Now, as soon as I start monitoring the JVM exits with a segfault (log
attached).
I've doubled checked my environment to ensure it matches the agent
installation documentation. TPTP_AC_HOME points to the TPTP home
directory, JAVA_PROFILER_HOME is set to
$TPTP_AC_HOME/plugins/org.eclipse.tptp.javaprofiler, LD_LIBRARY_PATH
includes $TPTP_AC_HOME/lib and $JAVA_PROFILER_HOME.
So, I'm not sure what else to check. Has anyone else encountered this?
- Chad
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="hs_err_pid17315.log"
Content-Disposition: inline;
filename="hs_err_pid17315.log"
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xb664af91, pid=17315, tid=3059710864
# Java VM: Java HotSpot(TM) Client VM (1.5.0_12-b04 mixed mode)
# Problematic frame:
# C [libhcclsm.so.4+0x3f91] ossRamboMultiSlotCopy+0xc9
--------------- T H R E A D ---------------
Current thread is native thread
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x0000008d
Registers:
EAX=0x00000001, EBX=0xb664ed70, ECX=0xacc995c0, EDX=0x00000004
ESP=0xb65f0c90, EBP=0xb65f0d18, ESI=0x00000071, EDI=0x0abf0990
EIP=0xb664af91, CR2=0x0000008d, EFLAGS=0x00210213
Top of Stack: (sp=0xb65f0c90)
0xb65f0c90: 00000014 00000011 ffffffff b65f0d80
0xb65f0ca0: b65f0d70 08ccf968 b6aab172 0024ebb1
0xb65f0cb0: 00000000 00000001 00000075 00000000
0xb65f0cc0: 00000001 00000000 0035a8b8 00000007
0xb65f0cd0: 00323ff4 00325120 00000004 b65f0cf8
0xb65f0ce0: 002502ee 00325120 00000071 acc995c0
0xb65f0cf0: 0aed5010 00000071 acc992e0 acc992e0
0xb65f0d00: acc992e0 00000001 00000005 0abf099c
Instructions: (pc=0xb664af91)
0xb664af81: 45 e8 8b 45 08 8b 00 c1 ea 05 89 45 a8 89 55 c0
0xb664af91: f6 80 8c 00 00 00 08 74 13 89 f6 e8 73 d8 ff ff
Stack: [0xb5bf7000,0xb65f8000), sp=0xb65f0c90, free space=10215k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libtransportSupport.so.4+0x29b2] ipcMemWriteWithDIME+0x4e
C [libtptpAgentBase.so.4+0xa159] sendData__16DataProviderImpliPciP13DIME_HEADER_Ti+0x81
C [libtptpAgentBase.so.4+0xa0c0] sendData__16DataProviderImpliPci+0x4c
C [libACCollector.so+0x5f15] ACCollector_SendData+0x25
C [libJPIAgent.so+0x964d]
C [libJPIAgent.so+0x990f]
C [libJPIAgent.so+0xae43]
C [libJPIAgent.so+0x6a65]
C [libACCollector.so+0x611e]
C [libtptpAgentBase.so.4+0x86b5] processCommand__17BaseCollectorImplP8CmdBlock+0x121
C [libACCollector.so+0x5a5c]
C [libtptpAgentBase.so.4+0x7171] processOneMessage__13BaseAgentImplPc+0x2b9
C [libtptpAgentBase.so.4+0x6d96] processRecdMessages__13BaseAgentImplPci+0x142
C [libtptpAgentBase.so.4+0x6b8c] handleMessages__13BaseAgentImplPv+0x214
C [libpthread.so.0+0x545b]
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x099925e0 JavaThread "TP-Monitor" daemon [_thread_blocked, id=17357]
0x0a3c48e8 JavaThread "TP-Processor4" daemon [_thread_in_native, id=17356]
0x0998fcb0 JavaThread "TP-Processor3" daemon [_thread_blocked, id=17355]
0x0a3cd288 JavaThread "TP-Processor2" daemon [_thread_blocked, id=17354]
0x09283aa0 JavaThread "TP-Processor1" daemon [_thread_blocked, id=17353]
0x0a264868 JavaThread "http-8080-Monitor" [_thread_blocked, id=17352]
0x0a46a588 JavaThread "http-8080-Processor25" daemon [_thread_blocked, id=17351]
0x0a46a400 JavaThread "http-8080-Processor24" daemon [_thread_in_native, id=17350]
0x0aff5c20 JavaThread "http-8080-Processor23" daemon [_thread_blocked, id=17349]
0x0aff5a80 JavaThread "http-8080-Processor22" daemon [_thread_blocked, id=17348]
0x0956f3b0 JavaThread "http-8080-Processor21" daemon [_thread_blocked, id=17347]
0x0b021898 JavaThread "http-8080-Processor20" daemon [_thread_blocked, id=17346]
0x0afeff60 JavaThread "http-8080-Processor19" daemon [_thread_blocked, id=17345]
0x09b82df8 JavaThread "http-8080-Processor18" daemon [_thread_blocked, id=17344]
0x0b021e10 JavaThread "http-8080-Processor17" daemon [_thread_blocked, id=17343]
0x0afd5f70 JavaThread "http-8080-Processor16" daemon [_thread_blocked, id=17342]
0x0afed380 JavaThread "http-8080-Processor15" daemon [_thread_blocked, id=17341]
0x0ab37698 JavaThread "http-8080-Processor14" daemon [_thread_blocked, id=17340]
0x09b345f8 JavaThread "http-8080-Processor13" daemon [_thread_blocked, id=17339]
0x099f52c8 JavaThread "http-8080-Processor12" daemon [_thread_blocked, id=17338]
0x09b33ac0 JavaThread "http-8080-Processor11" daemon [_thread_blocked, id=17337]
0x0affa138 JavaThread "http-8080-Processor10" daemon [_thread_blocked, id=17336]
0x0aabdba8 JavaThread "http-8080-Processor9" daemon [_thread_blocked, id=17335]
0x0aff8140 JavaThread "http-8080-Processor8" daemon [_thread_blocked, id=17334]
0x099f5c28 JavaThread "http-8080-Processor7" daemon [_thread_blocked, id=17333]
0x0b029d70 JavaThread "http-8080-Processor6" daemon [_thread_blocked, id=17332]
0x09cdae20 JavaThread "http-8080-Processor5" daemon [_thread_blocked, id=17331]
0x0aabb8c8 JavaThread "http-8080-Processor4" daemon [_thread_blocked, id=17330]
0x099f55c8 JavaThread "http-8080-Processor3" daemon [_thread_blocked, id=17329]
0x0a469090 JavaThread "http-8080-Processor2" daemon [_thread_blocked, id=17328]
0x0aff3730 JavaThread "http-8080-Processor1" daemon [_thread_blocked, id=17327]
0x09cc3028 JavaThread "ContainerBackgroundProcessor[StandardEngine[Catalina]]" daemon [_thread_blocked, id=17326]
0x0a351870 JavaThread "Timer-0" daemon [_thread_blocked, id=17325]
0x08f5ded8 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=17323]
0x08eab300 JavaThread "CompilerThread0" daemon [_thread_blocked, id=17322]
0x08f4e3f0 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=17321]
0x08de5700 JavaThread "Finalizer" daemon [_thread_blocked, id=17319]
0x08f10cc8 JavaThread "Reference Handler" daemon [_thread_blocked, id=17318]
0x08cd4218 JavaThread "main" [_thread_in_native, id=17315]
Other Threads:
0x08e73cd8 VMThread [id=17317]
0x08f82690 WatcherThread [id=17324]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 1920K, used 166K [0xa8690000, 0xa88a0000, 0xa8b70000)
eden space 1728K, 9% used [0xa8690000, 0xa86b9ab0, 0xa8840000)
from space 192K, 0% used [0xa8840000, 0xa8840000, 0xa8870000)
to space 192K, 0% used [0xa8870000, 0xa8870000, 0xa88a0000)
tenured generation total 24760K, used 14855K [0xa8b70000, 0xaa39e000, 0xac690000)
the space 24760K, 59% used [0xa8b70000, 0xa99f1db8, 0xa99f1e00, 0xaa39e000)
compacting perm gen total 24576K, used 24389K [0xac690000, 0xade90000, 0xb0690000)
the space 24576K, 99% used [0xac690000, 0xade61488, 0xade61600, 0xade90000)
No shared spaces configured.
Dynamic libraries:
001c6000-001df000 r-xp 00000000 08:03 1423684 /lib/ld-2.5.so
001df000-001e0000 r-xp 00019000 08:03 1423684 /lib/ld-2.5.so
001e0000-001e1000 rwxp 0001a000 08:03 1423684 /lib/ld-2.5.so
001e8000-00322000 r-xp 00000000 08:03 1423735 /lib/libc-2.5.so
00322000-00324000 r-xp 0013a000 08:03 1423735 /lib/libc-2.5.so
00324000-00325000 rwxp 0013c000 08:03 1423735 /lib/libc-2.5.so
00325000-00328000 rwxp 00325000 00:00 0
0032a000-0032c000 r-xp 00000000 08:03 1424364 /lib/libdl-2.5.so
0032c000-0032d000 r-xp 00001000 08:03 1424364 /lib/libdl-2.5.so
0032d000-0032e000 rwxp 00002000 08:03 1424364 /lib/libdl-2.5.so
00330000-00355000 r-xp 00000000 08:03 1423681 /lib/libm-2.5.so
00355000-00356000 r-xp 00024000 08:03 1423681 /lib/libm-2.5.so
00356000-00357000 rwxp 00025000 08:03 1423681 /lib/libm-2.5.so
00359000-0036c000 r-xp 00000000 08:03 1424369 /lib/libpthread-2.5.so
0036c000-0036d000 r-xp 00012000 08:03 1424369 /lib/libpthread-2.5.so
0036d000-0036e000 rwxp 00013000 08:03 1424369 /lib/libpthread-2.5.so
0036e000-00370000 rwxp 0036e000 00:00 0
00581000-0058c000 r-xp 00000000 08:03 1424370 /lib/libgcc_s-4.1.2-20070626.so.1
0058c000-0058d000 rwxp 0000a000 08:03 1424370 /lib/libgcc_s-4.1.2-20070626.so.1
00865000-00874000 r-xp 00000000 08:03 1424374 /lib/libresolv-2.5.so
00874000-00875000 r-xp 0000e000 08:03 1424374 /lib/libresolv-2.5.so
00875000-00876000 rwxp 0000f000 08:03 1424374 /lib/libresolv-2.5.so
00876000-00878000 rwxp 00876000 00:00 0
00b34000-00b47000 r-xp 00000000 08:03 1424390 /lib/libnsl-2.5.so
00b47000-00b48000 r-xp 00012000 08:03 1424390 /lib/libnsl-2.5.so
00b48000-00b49000 rwxp 00013000 08:03 1424390 /lib/libnsl-2.5.so
00b49000-00b4b000 rwxp 00b49000 00:00 0
08048000-08057000 r-xp 00000000 08:03 1488904 /opt/jdk1.5.0_12/bin/java
08057000-08059000 rwxp 0000e000 08:03 1488904 /opt/jdk1.5.0_12/bin/java
08cbe000-0b13b000 rwxp 08cbe000 00:00 0
a49e7000-a4a08000 rwxs 00000000 00:08 229378 /SYSV6d03eca3 (deleted)
a4a08000-a4a09000 --xp a4a08000 00:00 0
a4a09000-a5409000 rwxp a4a09000 00:00 0
a5409000-a542a000 rwxs 00000000 00:08 229378 /SYSV6d03eca3 (deleted)
a542a000-a552c000 rwxs 00000000 00:08 131073 /SYSV6d03ec93 (deleted)
a552c000-a55b0000 r-xs 00000000 08:03 1714704 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/xmltooling-trunk-jdk-1.5.jar
a55b0000-a5616000 r-xs 00000000 08:03 1714703 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/xmlsec-1.4.1.jar
a5616000-a5641000 r-xs 00000000 08:03 1714702 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/vt-ldap-2.8.1.jar
a5641000-a56a1000 r-xs 00000000 08:03 1714701 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/velocity-1.5.jar
a56a1000-a56f2000 r-xs 00000000 08:03 1714700 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.5.0-webmvc.jar
a56f2000-a5729000 r-xs 00000000 08:03 1714699 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.5.0-web.jar
a5729000-a576c000 r-xs 00000000 08:03 1714698 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.5.0-core.jar
a576c000-a57d8000 r-xs 00000000 08:03 1714697 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.5.0-context.jar
a57d8000-a57ef000 r-xs 00000000 08:03 1714696 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.5.0-context-support.jar
a57ef000-a5860000 r-xs 00000000 08:03 1714695 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.5.0-beans.jar
a5860000-a586d000 r-xs 00000000 08:03 1714694 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.0-commons-logging.jar
a586d000-a58f9000 r-xs 00000000 08:03 1714693 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/spring-2.0-commons-collections.jar
a58f9000-a58fd000 r-xs 00000000 08:03 1714692 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/slf4j-api-1.4.3.jar
a58fd000-a5901000 r-xs 00000000 08:03 1714690 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/script-1.0ri-api.jar
a5901000-a590b000 r-xs 00000000 08:03 1714689 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/rhino-engine.jar
a590b000-a59b9000 r-xs 00000000 08:03 1714688 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/rhino-1.6R5.jar
a59b9000-a59d1000 r-xs 00000000 08:03 1714687 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/openws-trunk-jdk-1.5.jar
a59d1000-a5ac3000 r-xs 00000000 08:03 1714686 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/opensaml-trunk-jdk-1.5.jar
a5ac3000-a5b45000 r-xs 00000000 08:03 1714679 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/joda-time-1.5.1.jar
a5b45000-a5b50000 r-xs 00000000 08:03 1714673 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/commons-pool-1.2.jar
a5b50000-a5b83000 r-xs 00000000 08:03 1714672 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/commons-lang-2.1.jar
a5b83000-a5bce000 r-xs 00000000 08:03 1714671 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/commons-httpclient-3.1.jar
a5bce000-a5c57000 r-xs 00000000 08:03 1714670 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/commons-collections-3.1.jar
a5c57000-a5ced000 r-xs 00000000 08:03 1714668 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/c3p0-0.9.1.2.jar
a5ced000-a5e68000 r-xs 00000000 08:03 1714667 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/bcprov-jdk14-138.jar
a5e68000-a5e6b000 --xp a5e68000 00:00 0
a5e6b000-a5ee9000 rwxp a5e6b000 00:00 0
a5ee9000-a5eec000 --xp a5ee9000 00:00 0
a5eec000-a5f6a000 rwxp a5eec000 00:00 0
a5f6a000-a5f6d000 --xp a5f6a000 00:00 0
a5f6d000-a5feb000 rwxp a5f6d000 00:00 0
a5feb000-a5fee000 --xp a5feb000 00:00 0
a5fee000-a606c000 rwxp a5fee000 00:00 0
a606c000-a606f000 --xp a606c000 00:00 0
a606f000-a60ed000 rwxp a606f000 00:00 0
a60ed000-a60f0000 --xp a60ed000 00:00 0
a60f0000-a616e000 rwxp a60f0000 00:00 0
a616e000-a6171000 --xp a616e000 00:00 0
a6171000-a61ef000 rwxp a6171000 00:00 0
a61ef000-a61f2000 --xp a61ef000 00:00 0
a61f2000-a6270000 rwxp a61f2000 00:00 0
a6270000-a6273000 --xp a6270000 00:00 0
a6273000-a62f1000 rwxp a6273000 00:00 0
a62f1000-a62f4000 --xp a62f1000 00:00 0
a62f4000-a6372000 rwxp a62f4000 00:00 0
a6372000-a6375000 --xp a6372000 00:00 0
a6375000-a63f3000 rwxp a6375000 00:00 0
a63f3000-a63f6000 --xp a63f3000 00:00 0
a63f6000-a6474000 rwxp a63f6000 00:00 0
a6474000-a6477000 --xp a6474000 00:00 0
a6477000-a64f5000 rwxp a6477000 00:00 0
a64f5000-a64f8000 --xp a64f5000 00:00 0
a64f8000-a6576000 rwxp a64f8000 00:00 0
a6576000-a657a000 r-xp 00000000 08:03 1423526 /lib/libnss_dns-2.5.so
a657a000-a657b000 r-xp 00003000 08:03 1423526 /lib/libnss_dns-2.5.so
a657b000-a657c000 rwxp 00004000 08:03 1423526 /lib/libnss_dns-2.5.so
a6589000-a658c000 --xp a6589000 00:00 0
a658c000-a660a000 rwxp a658c000 00:00 0
a6614000-a6654000 r-xs 00000000 08:03 1714685 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/not-yet-commons-ssl-0.3.9.jar
a6654000-a6657000 --xp a6654000 00:00 0
a6657000-a66d5000 rwxp a6657000 00:00 0
a66d5000-a66d8000 --xp a66d5000 00:00 0
a66d8000-a6756000 rwxp a66d8000 00:00 0
a6756000-a6759000 --xp a6756000 00:00 0
a6759000-a67d7000 rwxp a6759000 00:00 0
a67d7000-a67da000 --xp a67d7000 00:00 0
a67da000-a6858000 rwxp a67da000 00:00 0
a6858000-a685b000 --xp a6858000 00:00 0
a685b000-a68d9000 rwxp a685b000 00:00 0
a68d9000-a68dc000 --xp a68d9000 00:00 0
a68dc000-a695a000 rwxp a68dc000 00:00 0
a695a000-a695d000 --xp a695a000 00:00 0
a695d000-a69db000 rwxp a695d000 00:00 0
a69db000-a6a5d000 r-xs 00000000 08:03 1714691 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/shib-common-trunk-jdk-1.5.jar
a6a6a000-a6a98000 r-xs 00000000 08:03 1714684 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/logback-core-0.9.8.jar
a6a98000-a6ab6000 r-xs 00000000 08:03 1714681 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/logback-classic-0.9.8.jar
a6ab6000-a6adb000 r-xs 00000000 08:03 1714678 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/jgrapht-jdk1.5.jar
a6adb000-a6ade000 --xp a6adb000 00:00 0
a6ade000-a6b5c000 rwxp a6ade000 00:00 0
a6b5c000-a6b5f000 --xp a6b5c000 00:00 0
a6b5f000-a6bdd000 rwxp a6b5f000 00:00 0
a6bdd000-a6be0000 --xp a6bdd000 00:00 0
a6be0000-a6c5e000 rwxp a6be0000 00:00 0
a6c5e000-a6c61000 --xp a6c5e000 00:00 0
a6c61000-a6cdf000 rwxp a6c61000 00:00 0
a6cdf000-a6ce2000 --xp a6cdf000 00:00 0
a6ce2000-a6d60000 rwxp a6ce2000 00:00 0
a6d60000-a6d84000 r-xs 00000000 08:03 1714674 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/identityprovider-trunk.jar
a6d90000-a6d97000 r-xs 00000000 08:03 427501 /usr/lib/gconv/gconv-modules.cache
a6d97000-a6d9a000 r-xs 00000000 08:03 1714680 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/log4j-over-slf4j-1.4.3.jar
a6d9a000-a6d9e000 r-xs 00000000 08:03 1714677 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/jcl104-over-slf4j-1.4.3.jar
a6d9e000-a6da1000 r-xs 00000000 08:03 1714676 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/jargs-1.0.jar
a6da1000-a6dad000 r-xs 00000000 08:03 1714669 /opt/apache-tomcat-5.5.23/work/Catalina/localhost/idp/WEB-IN F/lib/commons-codec-1.3.jar
a6dad000-a6db0000 --xp a6dad000 00:00 0
a6db0000-a6e2e000 rwxp a6db0000 00:00 0
a6e2e000-a6e31000 --xp a6e2e000 00:00 0
a6e31000-a6eaf000 rwxp a6e31000 00:00 0
a6eaf000-a6eb2000 --xp a6eaf000 00:00 0
a6eb2000-a6f30000 rwxp a6eb2000 00:00 0
a6f30000-a6f33000 --xp a6f30000 00:00 0
a6f33000-a6fb1000 rwxp a6f33000 00:00 0
a6fb1000-a6fb4000 --xp a6fb1000 00:00 0
a6fb4000-a7032000 rwxp a6fb4000 00:00 0
a7032000-a7035000 --xp a7032000 00:00 0
a7035000-a70b3000 rwxp a7035000 00:00 0
a70b3000-a79e5000 r-xs 00000000 08:03 1555952 /home/shibidp/shibboleth-idp/war/idp.war
a79e5000-a79f6000 r-xp 00000000 08:03 1488238 /opt/jdk1.5.0_12/jre/lib/i386/libnet.so
a79f6000-a79f7000 rwxp 00011000 08:03 1488238 /opt/jdk1.5.0_12/jre/lib/i386/libnet.so
a79f7000-a7a2c000 r-xs 00000000 08:03 1556107 /opt/apache-tomcat-5.5.23/server/lib/catalina-cluster.jar
a7a2c000-a7a49000 r-xs 00000000 08:03 1556108 /opt/apache-tomcat-5.5.23/server/lib/catalina-optional.jar
a7a49000-a7a59000 r-xs 00000000 08:03 1556109 /opt/apache-tomcat-5.5.23/server/lib/catalina-storeconfig.ja r
a7a59000-a7a60000 r-xs 00000000 08:03 1556118 /opt/apache-tomcat-5.5.23/server/lib/tomcat-apr.jar
a7a60000-a7a9f000 r-xs 00000000 08:03 1556122 /opt/apache-tomcat-5.5.23/server/lib/tomcat-util.jar
a7a9f000-a7ab5000 r-xs 00000000 08:03 1556120 /opt/apache-tomcat-5.5.23/server/lib/tomcat-http.jar
a7ab5000-a7aba000 r-xs 00000000 08:03 1556119 /opt/apache-tomcat-5.5.23/server/lib/tomcat-coyote.jar
a7aba000-a7ad5000 r-xs 00000000 08:03 1556111 /opt/apache-tomcat-5.5.23/server/lib/commons-modeler-2.0.jar
a7ad5000-a7adb000 r-xs 00000000 08:03 1556105 /opt/apache-tomcat-5.5.23/server/lib/catalina-ant-jmx.jar
a7adb000-a7b7b000 r-xs 00000000 08:03 1556110 /opt/apache-tomcat-5.5.23/server/lib/catalina.jar
a7b7b000-a7ba0000 r-xs 00000000 08:03 1556117 /opt/apache-tomcat-5.5.23/server/lib/tomcat-ajp.jar
a7ba0000-a7ba7000 r-xs 00000000 08:03 1556106 /opt/apache-tomcat-5.5.23/server/lib/catalina-ant.jar
a7ba7000-a7bac000 r-xs 00000000 08:03 1556113 /opt/apache-tomcat-5.5.23/server/lib/servlets-default.jar
a7bac000-a7bb4000 r-xs 00000000 08:03 1556121 /opt/apache-tomcat-5.5.23/server/lib/tomcat-jkstatus-ant.jar
a7bb4000-a7bba000 r-xs 00000000 08:03 1556116 /opt/apache-tomcat-5.5.23/server/lib/servlets-webdav.jar
a7bba000-a7bc7000 r-xs 00000000 08:03 1556090 /opt/apache-tomcat-5.5.23/common/lib/jsp-api.jar
a7bc7000-a7bef000 r-xs 00000000 08:03 1556091 /opt/apache-tomcat-5.5.23/common/lib/naming-factory-dbcp.jar
a7bef000-a7d18000 r-xs 00000000 08:03 1556087 /opt/apache-tomcat-5.5.23/common/lib/jasper-compiler-jdt.jar
a7d18000-a7d34000 r-xs 00000000 08:03 1556086 /opt/apache-tomcat-5.5.23/common/lib/commons-el.jar
a7d34000-a7d47000 r-xs 00000000 08:03 1556089 /opt/apache-tomcat-5.5.23/common/lib/jasper-runtime.jar
a7d47000-a7d60000 r-xs 00000000 08:03 1556094 /opt/apache-tomcat-5.5.23/common/lib/servlet-api.jar
a7d60000-a7dc4000 r-xs 00000000 08:03 1556088 /opt/apache-tomcat-5.5.23/common/lib/jasper-compiler.jar
a7dc4000-a7dd0000 r-xs 00000000 08:03 1556093 /opt/apache-tomcat-5.5.23/common/lib/naming-resources.jar
a7dd0000-a7dd8000 r-xs 00000000 08:03 1556092 /opt/apache-tomcat-5.5.23/common/lib/naming-factory.jar
a7dd8000-a7de1000 r-xs 00000000 08:03 1556083 /opt/apache-tomcat-5.5.23/common/i18n/tomcat-i18n-es.jar
a7de1000-a7deb000 r-xs 00000000 08:03 1556082 /opt/apache-tomcat-5.5.23/common/i18n/tomcat-i18n-en.jar
a7deb000-a7df3000 r-xs 00000000 08:03 1556084 /opt/apache-tomcat-5.5.23/common/i18n/tomcat-i18n-fr.jar
a7df3000-a7dfc000 r-xs 00000000 08:03 1556085 /opt/apache-tomcat-5.5.23/common/i18n/tomcat-i18n-ja.jar
a7dfc000-a7e00000 r-xs 00000000 08:03 1556074 /opt/apache-tomcat-5.5.23/bin/tomcat-juli.jar
a7e00000-a7e06000 r-xs 00000000 08:03 1556055 /opt/apache-tomcat-5.5.23/bin/bootstrap.jar
a7e06000-a7e2d000 r-xs 00000000 08:03 1488272 /opt/jdk1.5.0_12/jre/lib/ext/sunjce_provider.jar
a7e2d000-a7e58000 r-xs 00000000 08:03 1488273 /opt/jdk1.5.0_12/jre/lib/ext/sunpkcs11.jar
a7e58000-a7fc4000 r-xs 00000000 08:03 1490892 /opt/jdk1.5.0_12/jre/lib/ext/bcprov-jdk15-137.jar
a7fc4000-a8089000 r-xs 00000000 08:03 1488877 /opt/jdk1.5.0_12/jre/lib/ext/localedata.jar
a8089000-a808a000 --xp a8089000 00:00 0
a808a000-a810a000 rwxp a808a000 00:00 0
a810a000-a810d000 --xp a810a000 00:00 0
a810d000-a818b000 rwxp a810d000 00:00 0
a818b000-a818e000 --xp a818b000 00:00 0
a818e000-a820c000 rwxp a818e000 00:00 0
a820c000-a820f000 --xp a820c000 00:00 0
a820f000-a828d000 rwxp a820f000 00:00 0
a828d000-a848d000 r-xp 00000000 08:03 427237 /usr/lib/locale/locale-archive
a848d000-a8490000 --xp a848d000 00:00 0
a8490000-a850e000 rwxp a8490000 00:00 0
a850e000-a8511000 --xp a850e000 00:00 0
a8511000-a858f000 rwxp a8511000 00:00 0
a858f000-a8590000 --xp a858f000 00:00 0
a8590000-a861d000 rwxp a8590000 00:00 0
a861d000-a8631000 rwxp a861d000 00:00 0
a8631000-a863e000 rwxp a8631000 00:00 0
a863e000-a864f000 rwxp a863e000 00:00 0
a864f000-a8651000 rwxp a864f000 00:00 0
a8651000-a865e000 rwxp a8651000 00:00 0
a865e000-a866f000 rwxp a865e000 00:00 0
a866f000-a867b000 rwxp a866f000 00:00 0
a867b000-a868f000 rwxp a867b000 00:00 0
a868f000-a88a0000 rwxp a868f000 00:00 0
a88a0000-a8b70000 rwxp a88a0000 00:00 0
a8b70000-aa39e000 rwxp a8b70000 00:00 0
aa39e000-ac690000 rwxp aa39e000 00:00 0
ac690000-ade90000 rwxp ac690000 00:00 0
ade90000-b0690000 rwxp ade90000 00:00 0
b0690000-b0697000 r-xs 00000000 08:03 1556060 /opt/apache-tomcat-5.5.23/bin/commons-logging-api.jar
b0697000-b06a9000 rwxp b0697000 00:00 0
b06a9000-b0717000 rwxp b06a9000 00:00 0
b0717000-b0b6f000 rwxp b0717000 00:00 0
b0b6f000-b2717000 rwxp b0b6f000 00:00 0
b2717000-b2f86000 r-xs 00000000 08:03 1488876 /opt/jdk1.5.0_12/jre/lib/charsets.jar
b2f86000-b2f9b000 r-xs 00000000 08:03 1488276 /opt/jdk1.5.0_12/jre/lib/jce.jar
b2f9b000-b3020000 r-xs 00000000 08:03 1488817 /opt/jdk1.5.0_12/jre/lib/jsse.jar
b3020000-b3089000 rwxp b3020000 00:00 0
b3089000-b56ae000 r-xs 00000000 08:03 1488898 /opt/jdk1.5.0_12/jre/lib/rt.jar
b56ae000-b599e000 r-xs 00000000 08:03 1555915 /opt/apache-tomcat-5.5.23/common/endorsed/xalan-2.7.0.jar
b599e000-b59ce000 r-xs 00000000 08:03 1555922 /opt/apache-tomcat-5.5.23/common/endorsed/xerces-2.9.0-xml-a pis.jar
b59ce000-b59fd000 r-xs 00000000 08:03 1555920 /opt/apache-tomcat-5.5.23/common/endorsed/xalan-2.7.0-serial izer.jar
b59fd000-b5b28000 r-xs 00000000 08:03 1555921 /opt/apache-tomcat-5.5.23/common/endorsed/xerces-2.9.0-xerce sImpl.jar
b5b28000-b5b37000 r-xp 00000000 08:03 1488235 /opt/jdk1.5.0_12/jre/lib/i386/libzip.so
b5b37000-b5b39000 rwxp 0000e000 08:03 1488235 /opt/jdk1.5.0_12/jre/lib/i386/libzip.so
b5b39000-b5b5a000 r-xp 00000000 08:03 1488233 /opt/jdk1.5.0_12/jre/lib/i386/libjava.so
b5b5a000-b5b5c000 rwxp 00020000 08:03 1488233 /opt/jdk1.5.0_12/jre/lib/i386/libjava.so
b5b5c000-b5b67000 r-xp 00000000 08:03 1488232 /opt/jdk1.5.0_12/jre/lib/i386/libverify.so
b5b67000-b5b68000 rwxp 0000b000 08:03 1488232 /opt/jdk1.5.0_12/jre/lib/i386/libverify.so
b5b68000-b5b71000 r-xp 00000000 08:03 1423528 /lib/libnss_files-2.5.so
b5b71000-b5b72000 r-xp 00008000 08:03 1423528 /lib/libnss_files-2.5.so
b5b72000-b5b73000 rwxp 00009000 08:03 1423528 /lib/libnss_files-2.5.so
b5b73000-b5b75000 r-xs 00000000 08:03 1556114 /opt/apache-tomcat-5.5.23/server/lib/servlets-invoker.jar
b5b75000-b5b78000 r-xs 00000000 08:03 1556059 /opt/apache-tomcat-5.5.23/bin/commons-daemon.jar
b5b78000-b5b80000 rwxs 00000000 08:03 388258 /tmp/hsperfdata_shibidp/17315
b5b80000-b5be1000 r-xp 00000000 08:03 1359325 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJIE.so
b5be1000-b5bf3000 rwxp 00061000 08:03 1359325 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJIE.so
b5bf3000-b5bf7000 rwxp b5bf3000 00:00 0
b5bf7000-b5bf8000 --xp b5bf7000 00:00 0
b5bf8000-b65f8000 rwxp b5bf8000 00:00 0
b65f8000-b6630000 r-xp 00000000 08:03 433777 /usr/lib/libstdc++-3-libc6.2-2-2.10.0.so
b6630000-b6638000 rwxp 00038000 08:03 433777 /usr/lib/libstdc++-3-libc6.2-2-2.10.0.so
b6638000-b663a000 rwxp b6638000 00:00 0
b663a000-b6644000 r-xp 00000000 08:03 1359321 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libCGAdaptor.so
b6644000-b6647000 rwxp 00009000 08:03 1359321 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libCGAdaptor.so
b6647000-b664e000 r-xp 00000000 08:03 1358848 /opt/eclipse-tptp-agent/lib/libhcclsm.so.4.4.0
b664e000-b664f000 rwxp 00006000 08:03 1358848 /opt/eclipse-tptp-agent/lib/libhcclsm.so.4.4.0
b664f000-b6650000 rwxp b664f000 00:00 0
b6650000-b6659000 r-xp 00000000 08:03 1358839 /opt/eclipse-tptp-agent/lib/libhcclco.so.4.4.0
b6659000-b665a000 rwxp 00008000 08:03 1358839 /opt/eclipse-tptp-agent/lib/libhcclco.so.4.4.0
b665a000-b69a9000 r-xp 00000000 08:03 1358904 /opt/eclipse-tptp-agent/lib/libxerces-c.so.26
b69a9000-b6a5f000 rwxp 0034e000 08:03 1358904 /opt/eclipse-tptp-agent/lib/libxerces-c.so.26
b6a5f000-b6a61000 rwxp b6a5f000 00:00 0
b6a61000-b6a75000 r-xp 00000000 08:03 1358893 /opt/eclipse-tptp-agent/lib/libtptpConfig.so.4.4.0
b6a75000-b6a78000 rwxp 00013000 08:03 1358893 /opt/eclipse-tptp-agent/lib/libtptpConfig.so.4.4.0
b6a78000-b6a7b000 rwxp b6a78000 00:00 0
b6a7b000-b6a86000 r-xp 00000000 08:03 1358896 /opt/eclipse-tptp-agent/lib/libtptpLogUtils.so.4.4.0
b6a86000-b6a88000 rwxp 0000a000 08:03 1358896 /opt/eclipse-tptp-agent/lib/libtptpLogUtils.so.4.4.0
b6a88000-b6aa4000 r-xp 00000000 08:03 1358899 /opt/eclipse-tptp-agent/lib/libtptpUtils.so.4.4.0
b6aa4000-b6aa8000 rwxp 0001b000 08:03 1358899 /opt/eclipse-tptp-agent/lib/libtptpUtils.so.4.4.0
b6aa8000-b6ab7000 r-xp 00000000 08:03 1358881 /opt/eclipse-tptp-agent/lib/libtptpAgentBase.so.4.4.0
b6ab7000-b6aba000 rwxp 0000e000 08:03 1358881 /opt/eclipse-tptp-agent/lib/libtptpAgentBase.so.4.4.0
b6aba000-b6acd000 r-xp 00000000 08:03 1359320 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libACCollector.so
b6acd000-b6ad1000 rwxp 00012000 08:03 1359320 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libACCollector.so
b6ad1000-b6aea000 r-xp 00000000 08:03 1359322 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libCGProf.so
b6aea000-b6aef000 rwxp 00018000 08:03 1359322 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libCGProf.so
b6aef000-b6af2000 r-xp 00000000 08:03 1423683 /lib/libuuid.so.1.2
b6af2000-b6af3000 rwxp 00002000 08:03 1423683 /lib/libuuid.so.1.2
b6af4000-b6af6000 r-xs 00000000 08:03 1488274 /opt/jdk1.5.0_12/jre/lib/ext/dnsns.jar
b6af6000-b6afa000 r-xp 00000000 08:03 1358902 /opt/eclipse-tptp-agent/lib/libtransportSupport.so.4.4.0
b6afa000-b6afb000 rwxp 00003000 08:03 1358902 /opt/eclipse-tptp-agent/lib/libtransportSupport.so.4.4.0
b6afb000-b6aff000 r-xp 00000000 08:03 1358869 /opt/eclipse-tptp-agent/lib/libprocessControlUtil.so.4.4.0
b6aff000-b6b00000 rwxp 00003000 08:03 1358869 /opt/eclipse-tptp-agent/lib/libprocessControlUtil.so.4.4.0
b6b00000-b6b19000 r-xp 00000000 08:03 1359327 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJPIAgent.so
b6b19000-b6b1e000 rwxp 00018000 08:03 1359327 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJPIAgent.so
b6b1e000-b77c6000 rwxp b6b1e000 00:00 0
b77c6000-b77f9000 r-xp 00000000 08:03 1359326 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJPI.so
b77f9000-b7807000 rwxp 00032000 08:03 1359326 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJPI.so
b7807000-b7810000 r-xp 00000000 08:03 1359329 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libMartiniOSA.so
b7810000-b7812000 rwxp 00009000 08:03 1359329 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libMartiniOSA.so
b7812000-b7819000 r-xp 00000000 08:03 1359328 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJPIBootLoader.so
b7819000-b781b000 rwxp 00006000 08:03 1359328 /opt/eclipse-tptp-agent/plugins/org.eclipse.tptp.javaprofile r/libJPIBootLoader.so
b781b000-b7b8d000 r-xp 00000000 08:03 1488226 /opt/jdk1.5.0_12/jre/lib/i386/client/libjvm.so
b7b8d000-b7bab000 rwxp 00371000 08:03 1488226 /opt/jdk1.5.0_12/jre/lib/i386/client/libjvm.so
b7bab000-b7fc3000 rwxp b7bab000 00:00 0
b7fc3000-b7fc5000 r-xp 00000000 08:03 1358845 /opt/eclipse-tptp-agent/lib/libhccls.so.4.4.0
b7fc5000-b7fc7000 rwxp 00001000 08:03 1358845 /opt/eclipse-tptp-agent/lib/libhccls.so.4.4.0
b7fc7000-b7fcd000 r-xp 00000000 08:03 1488220 /opt/jdk1.5.0_12/jre/lib/i386/native_threads/libhpi.so
b7fcd000-b7fce000 rwxp 00006000 08:03 1488220 /opt/jdk1.5.0_12/jre/lib/i386/native_threads/libhpi.so
b7fce000-b7fcf000 rwxp b7fce000 00:00 0
b7fcf000-b7fd0000 r-xp b7fcf000 00:00 0
b7fd0000-b7fd1000 rwxp b7fd0000 00:00 0
b7fd1000-b7fd2000 r-xp b7fd1000 00:00 0 [vdso]
bfbd5000-bfbd8000 --xp bfbd5000 00:00 0
bfbd8000-bfdd5000 rwxp bfbd8000 00:00 0 [stack]
VM Arguments:
jvm_args: -agentlib:JPIBootLoader=JPIAgent;CGProf:execdetails=true -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogMa nager -Djava.util.logging.config.file=/opt/apache-tomcat-5.5.23/co nf/logging.properties -Djava.endorsed.dirs=/opt/apache-tomcat-5.5.23/common/endors ed -Dcatalina.base=/opt/apache-tomcat-5.5.23 -Dcatalina.home=/opt/apache-tomcat-5.5.23 -Djava.io.tmpdir=/opt/apache-tomcat-5.5.23/temp
java_command: org.apache.catalina.startup.Bootstrap start
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/opt/jdk1.5.0_12
PATH=/usr/local/bin:/bin:/usr/bin:/opt/jdk1.5.0_12/bin:/opt/ eclipse-tptp-agent/bin:/opt/jdk1.5.0_12/bin:/opt/eclipse-tpt p-agent/bin:/opt/jdk1.5.0_12/bin:/opt/eclipse-tptp-agent/bin :/opt/jdk1.5.0_12/bin:/opt/eclipse-tptp-agent/bin
LD_LIBRARY_PATH=/opt/jdk1.5.0_12/jre/lib/i386/client:/opt/jd k1.5.0_12/jre/lib/i386:/opt/jdk1.5.0_12/jre/../lib/i386::/op t/eclipse-tptp-agent/lib:/opt/eclipse-tptp-agent/lib::/opt/e clipse-tptp-agent/lib:/opt/eclipse-tptp-agent/plugins/org.ec lipse.tptp.javaprofiler:/opt/eclipse-tptp-agent/lib
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x32b1b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x32b1b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x28eb70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x28eb70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x28eb70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x290fc0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x2909f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGQUIT: [libjvm.so+0x2909f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x2909f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:CentOS release 5 (Final)
uname:Linux 2.6.18-8.1.15.el5 #1 SMP Mon Oct 22 08:32:04 EDT 2007 i686
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 10240k, CORE 0k, NPROC 16384, NOFILE 1024, AS infinity
load average:0.22 0.28 0.17
CPU:total 1 (cores per cpu 2, threads per core 1) family 15 model 33 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnowext, 3dnow
Memory: 4k page, physical 1035400k(65700k free), swap 522104k(522012k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_12-b04) for linux-x86, built on May 2 2007 03:26:22 by java_re with gcc 3.2.1-7a (J2SE release)
--------------030509080906000307090005--
Current Time: Mon Nov 17 10:32:17 EST 2025
Powered by FUDForum. Page generated in 0.27054 seconds
