Home » Eclipse Projects » Equinox » Difference between an OSGi bundle as jar/directory
Difference between an OSGi bundle as jar/directory [message #121304] Wed, 19 November 2008 11:01 Go to next message
I have a question regarding the difference between deploying an OSGi
bundle as a jar and as a directory.
I have some OSGi bundles in a directory. In eclipse I change the "Target
Platform" to compile and run against this directory location (equinox
bundles are available there as well). The problem I am running into is
that if I supply my bundles as directories I will received compile errors
in my eclipse. The bundles are found but the exported packages can't be
discovered. If I jar my bundles (exactly same
structure/manifest/resources) and replace the directory bundles with those
everything is working fine.
Anybody got a hint for me?
Cheers
Philipp
PS: Some of the bundles need to be deployed as directories, so I can't
stick with the solution to jar everything up :-)
Re: Difference between an OSGi bundle as jar/directory [message #121334 is a reply to message #121304] Thu, 20 November 2008 04:00 Go to previous messageGo to next message
There shouldn't be difference between jar and folder bundles. Are you
sure they have exactly the same structure? Also, what are the exact
errors you are receiving:
PDE cannot resolve the packages in the manifest
Java compiler cannot find the classes to compile your classes
Philipp Marx wrote:
> errors in my eclipse. The bundles are found but the exported packages
> can't be discovered. If I jar my bundles (exactly same
> those everything is working fine.
> Cheers
> Philipp
Re: Difference between an OSGi bundle as jar/directory [message #121389 is a reply to message #121334] Fri, 21 November 2008 08:28 Go to previous messageGo to next message
The PDE can resolve the bundles and the import packages (no error in the
Manifest) but the Java compiler (from within eclipse) can't "resolve the
import package".
The structure and content is both time exactly the same.
Cheers
Philipp
Re: Difference between an OSGi bundle as jar/directory [message #121405 is a reply to message #121389] Fri, 21 November 2008 09:27 Go to previous messageGo to next message
This most likely sounds like a bug and I suggest that you submit it to
the usual place [1] with detailed steps how it can be reproduced.
Before this, you can check the following things:
1) Are required bundles available In Plug-in Dependencies
2) What access rules have been set for the corresponding bundle (Project
Properties -> Java Build Path -> Libraries -> Plug-in Dependencies ->
<bundle> -> Access Rules
[1] https://bugs.eclipse.org/bugs/
Philipp Marx wrote:
> import package".
> Cheers
> Philipp
Re: Difference between an OSGi bundle as jar/directory [message #121412 is a reply to message #121405] Fri, 21 November 2008 09:43 Go to previous messageGo to next message
It doesn't show up in the dependencies section. Since I am using those
bundles as "Target Platform" is there a way to start eclipse with an
OSGI-console? Maybe this would reveal something (unresolved dependencies
within the Target Platform).
I don't think this is a bug (I rather think this is an error on my side
:-)). Funny thing is that I have some bundles which work as a directory
and some won't.
Cheers
Philipp
Re: Difference between an OSGi bundle as jar/directory [message #121449 is a reply to message #121412] Mon, 24 November 2008 11:04 Go to previous message
When you open the OSGi Framework launch configuration, in Bundles tab,
you can select Validate Bundles, which will resolve the bundles offline
(including those in your target platform) and report any problems found
before launching the framework.
Otherwise, you can add the following parameters to the command line:
-console -consoleLog
This will give you a console and also redirect any exceptions logged to
the console.
Philipp Marx wrote:
> and some won't.
> Cheers
> Philipp
Previous Topic:creating and using references
Next Topic:How Can a Bundle Start w/o the Calling Start Method
Current Time: Wed Nov 19 13:00:55 EST 2025
Powered by FUDForum. Page generated in 0.13797 seconds
