Home » Archived » Test and Performance Tools Platform (TPTP) » Unable to associate multiple TestCases with an artifact
Unable to associate multiple TestCases with an artifact [message #121270] Wed, 23 January 2008 07:21 Go to next message
I'm in the process of extendind TPTP in oder to run special JUnit test
cases. I also added extension to the artifact editor and noted that it
is impossible to associate more than one of my test cases with the
artifact. The testcases were created via 'Import to TPTP' (source is a
JUnit TestCase).
I figured out that the problem is being caused by an id with value '.'.
This id is beeng set (it seems intentionally) in
JUnitTestSuiteFacade.fixupResource(). But
ArtfactUtil.associateTestAsset() uses ConfigurationUtil.containsById()
which answers always true.
Is the described behaviour a bug or can a test artifact only be
associated with one JUnit test case?
Stefan
Re: Unable to associate multiple TestCases with an artifact [message #121303 is a reply to message #121270] Thu, 24 January 2008 06:19 Go to previous message
Hi Stefan,
Thanks for using TPTP in your project. This behavior is a bug. Can you
open a defect with the below details @
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
Component: Test.UI.ConfigEditors
Paul
"Stefan Holzknecht" <s.holzknecht@intershop.de> wrote in message
news:fn7bfp$e0r$1@build.eclipse.org...
> Hello,
> cases. I also added extension to the artifact editor and noted that it is
> impossible to associate more than one of my test cases with the artifact.
> The testcases were created via 'Import to TPTP' (source is a JUnit
> TestCase).
> JUnitTestSuiteFacade.fixupResource(). But ArtfactUtil.associateTestAsset()
> uses ConfigurationUtil.containsById() which answers always true.
> Is the described behaviour a bug or can a test artifact only be associated
> Stefan
Previous Topic:Is "Cumulative CPU time" supposed to be the same from run to run?
Next Topic:can tptp automate gui recoder macro out of eclipse
Current Time: Tue Dec 02 13:55:47 EST 2025
Powered by FUDForum. Page generated in 0.03601 seconds
