Home » Eclipse Projects » Equinox » Root file in P2-ized build
Root file in P2-ized build [message #121178] Thu, 13 November 2008 16:33
I'm trying to build 3.4.1 sources and p2-ize it. After running p2 director
on my build, there were a few root files missing in the new p2 layout. All
I got was eclipse.exe and eclipse.ini in addition to folders. Below are
the steps I took. Am I missing a flag somewhere?
1. I'm building the sdk component with build.xml in eclipsebuilder. All
sources are in our repository, unmodified after being checked out of
eclipse cvs.
2. untar the built archive and generate p2 metadata with this command line
../../../sun_java/j2sdk1.4.2_14/jre/bin/java -jar
/eclipse/plugins/org.eclipse.equinox.launcher_1.0.101.Test_B uild.jar
-data workspace -application
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator -flavor tooling
-metadataRepository "file:../repo" -artifactRepository "file:../repo"
-root "Eclipse SDK" -rootVersion 3.4.1 -source ./eclipse -append
-publishArtifacts -publishArtifactRepository
3. remove all update references to eclipse.org in repo files and
configuration/.settings/*.pref so it doesn't try to access eclipse.org.
3. run p2 director with this command line
-Declipse.p2.data.area=./eclipse_p2/p2 -jar
org.eclipse.equinox.p2.director.app.application -flavor tooling
-metadataRepository file:../repo -artifactRepository file:../repo
-installIU "Eclipse SDK" -version 3.4.1 -p2.os linux -p2.ws gtk -p2.arch
x86 -profile SDKProfile -profileProperties
org.eclipse.update.install.features=true -destination ./eclipse_p2
-bundlepool ./eclipse_p2 -consoleLog -roaming
Any pointers are appreciated. :)
Eirene
Previous Topic:Uninstalling features doesn't remove plug-ins
Next Topic:[p2] locate dropins folder programmatically
Current Time: Wed Nov 05 14:06:56 EST 2025
Powered by FUDForum. Page generated in 0.25436 seconds
