Home » Language IDEs » C / C++ IDE (CDT) » unable to build
unable to build [message #121164] Thu, 16 September 2004 18:57 Go to next message
Originally posted by: nomail.nomail.com
I cannot get my hello world to build under windows.
I have installed MinGW and put it in my user environment I can run
make/gcc/g++ from the command line.
I created a managed c/c++ project with a main.c source file. When I give
the command "Build All" nothing happens. The console remains a blank grey
panel. No files are created.
Re: unable to build [message #121182 is a reply to message #121164] Fri, 17 September 2004 01:30 Go to previous messageGo to next message
Please give a `clean` command before. (I think there is a little bug in
Eclipse !..)
Re: unable to build [message #121791 is a reply to message #121164] Mon, 27 September 2004 11:08 Go to previous message
Check if there is the make.exe in MinGW directory (if there isn't, copy the
mingw-make.exe and rename it as make.exe), or change the default build
preferences in CDT (from make to mingw-make).
Bye! :)
Francesco
Previous Topic:ReRun the indexer
Next Topic:less verbose console output while debugging
Current Time: Thu Nov 06 13:40:54 EST 2025
Powered by FUDForum. Page generated in 0.03749 seconds
