Home » Modeling » GMF (Graphical Modeling Framework) » Multiple Models on one screen
Multiple Models on one screen [message #121158] Mon, 23 April 2007 06:46 Go to next message
i want to have two Models in one screen. I tried to load each project in
a composite, but this doesn't really work. Can you say me, where i must
change the code or maybe a better way to do this?
Greetings
Re: Multiple Models on one screen [message #121184 is a reply to message #121158] Mon, 23 April 2007 07:25 Go to previous messageGo to next message
if they must be visible at the same time: How about simply arranging the
editor windows side by side?
If they should be in one editor and the user can switch between them,
then a MultiPageEditor should the trick (there are several post about
that here).
ciao,
elm
Re: Multiple Models on one screen [message #123066 is a reply to message #121184] Tue, 01 May 2007 06:06 Go to previous message
I searched for the postings of a multipage editor, but they don't really
helped me. Can you explain me how i start to load a model in a composite
or something like this.
Arranging the windows ist not a good solution, cause later i want to
load more than two models in this editor.
thanks
Previous Topic:Getting EObject id
Next Topic:Open Dialog on element creation
Current Time: Fri Jul 25 11:01:41 EDT 2025
Powered by FUDForum. Page generated in 1.05498 seconds
