| java.lang.reflect.InvocationTargetException [message #121136] |
Fri, 15 July 2005 09:15  |
Hi there, I am using
Eclipse IDE 3.1 (with WTP M5 specification)
JBoss 3.2.3 & 4.0.2,
XDoclet 1.2.2,
JDK 1.4.2.
And trying to create an EJB, during creation getting the following
Exception.
Please Help Me to solve this problem...
THANKS in Advance
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:357)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(DataModelWizard.java:245)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
org.eclipse.wst.common.componentcore.internal.resources.Virt ualComponent.getReferences(VirtualComponent.java:185)
org.eclipse.wst.common.componentcore.internal.operation.Crea teReferenceComponentsOp.addReferencedComponents(CreateRefere nceComponentsOp.java:58)
org.eclipse.wst.common.componentcore.internal.operation.Crea teReferenceComponentsOp.execute(CreateReferenceComponentsOp. java:30)
org.eclipse.jst.j2ee.application.internal.operations.AddComp onentToEnterpriseApplicationOp.execute(AddComponentToEnterpr iseApplicationOp.java:34)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.doExecute(ExtendableOperationImpl.java:129)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl$1.run(ExtendableOperationImpl.java:109)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1739)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.execute(ExtendableOperationImpl.java:115)
org.eclipse.jst.j2ee.internal.ejb.archiveoperations.EJBClien tComponentCreationOperation.runAddToEAROperation(EJBClientCo mponentCreationOperation.java:92)
org.eclipse.jst.j2ee.internal.ejb.archiveoperations.EJBClien tComponentCreationOperation.execute(EJBClientComponentCreati onOperation.java:65)
org.eclipse.jst.j2ee.internal.ejb.archiveoperations.EjbCompo nentCreationOperation.execute(EjbComponentCreationOperation. java:96)
org.eclipse.wst.common.frameworks.internal.ui.RunnableOperat ionWrapper.run(RunnableOperationWrapper.java:32)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
... 38 more
------------------------------------------------------------ ------------------------------------------------------------ --------------------------------------Please
Help Me
Thanks & Regards,
Parag
FUDForum. Page generated in 0.03403 seconds
