Home » Newcomers » Newcomers » Changing the LookAndFeel of Eclipse
Changing the LookAndFeel of Eclipse [message #121135] Thu, 01 December 2005 15:38 Go to next message
Originally posted by: weconsul.ptd.net
Is it possible to change the look and feel of Eclipse. I tried to add
this param to Eclipse but does not work. Is it because Eclipse is using
SWT. If so how can I change the IDE..
-vmargs Dswing.defaultlaf=com.sun.java.swing.plaf.motif.MotifLookAnd Feel
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Changing the LookAndFeel of Eclipse [message #121370 is a reply to message #121135] Fri, 02 December 2005 16:22 Go to previous messageGo to next message
Eclipse does not use Swing at all, which is why your system property has
not effect.
There are 2 look and feels shipped with Eclipse (see Preferences |
General | Appearance). I remember seeing a third-party alternate, I
think somewhere on http://www.eclipse-plugins.info
Note that you sometimes have to restart Eclipse to see the complete
effect of changing the Presentation Style preferences.
HTH,
Eric
Re: Changing the LookAndFeel of Eclipse [message #121416 is a reply to message #121370] Fri, 02 December 2005 20:16 Go to previous message
>> using SWT. If so how can I change the IDE..
> not effect.
> HTH,
> Eric
Thanks...
Previous Topic:buid help system by using eclipse 3.1.1
Next Topic:Running eclipse?
Current Time: Sat Nov 08 23:05:25 EST 2025
Powered by FUDForum. Page generated in 0.08585 seconds
