Home » Language IDEs » ServerTools (WTP) » Tomcat Launch Configuration Properties
Tomcat Launch Configuration Properties [message #121083] Fri, 15 July 2005 08:12
I use eclipse 3.1 wtp1.0M5 on a linux platform
Within my dynamic web project classes i need to load a shared object file
(dynamic library). therfore i set the LD_LIBRARY_PATH environment variable
in the tomcat launch configuration properties. but this variable seems to
be ignored on tomcat startup.
Using a java application run configuration, like lomboz does it, the
environment is set properly.
Can anybody confirm this behaviour, or can provide a solution/workaround ?
Greets
Jörg
Previous Topic:Moving from myeclipseide to wst
Next Topic:error publishing to tomcat
Current Time: Sat Nov 08 19:45:01 EST 2025
Powered by FUDForum. Page generated in 0.02480 seconds
