Home » Archived » Albireo » ctrl-c ctrl-v not working in 3.5
ctrl-c ctrl-v not working in 3.5 [message #11063] Mon, 13 July 2009 14:19 Go to next message
Originally posted by: jpeltzer.rossvideo.com
Has anyone else had the ctrl-x/ctrl-c/ctrl-v keys stop working in Eclipse
3.5?
They used to work perfectly in my Swing text fields but not anymore.
I have tried this on Java 6 u6 and Java 6 u14.
Confirmation or denials are both welcome responses.
James
Re: ctrl-c ctrl-v not working in 3.5 [message #11074 is a reply to message #11063] Wed, 15 July 2009 09:15 Go to previous messageGo to next message
After further testing/investigation,
To get these keys back, I had to disable the key filter in the
IBindingService. Apparently this will prevent all key bindings from working
(not an overly great solution). Any better workarounds out there?
James
"James Peltzer" <jpeltzer@rossvideo.com> wrote in message
news:h3ftvl$7f6$1@build.eclipse.org...
> 3.5?
> James
Re: ctrl-c ctrl-v not working in 3.5 [message #12453 is a reply to message #11074] Thu, 16 July 2009 09:31 Go to previous messageGo to next message
If you don't get an answer here then you should ask this on the
eclipse.platform newsgroup. I know that at least until 3.4.x that one step
that was taken in reaction to Ctrl+C/V/W was to introspect on the focus
control for copy()/cut()/paste() methods, and this was done specifically to
handle the case of a Swing control like a text field having focus. I'm
pretty sure that this would not have been intentionally changed in 3.5, so
there may be a regression that Eclipse UI needs to investigate.
Grant
news:h3kkp6$uh8$1@build.eclipse.org...
working
> James
Eclipse
> > 3.5?
> > Thanks,
> > James
Re: ctrl-c ctrl-v not working in 3.5 [message #12478 is a reply to message #12453] Thu, 16 July 2009 13:14 Go to previous message
Thanks for the heads up. I'll repost over there given that this thread
hasn't gotten a lot of action over the past 3 days.
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:h3na47$fq1$1@build.eclipse.org...
> step
> to
> Grant
> working
>> James
> Eclipse
>> > 3.5?
>> > Thanks,
>> > James
Re: ctrl-c ctrl-v not working in 3.5 [message #575299 is a reply to message #11063] Wed, 15 July 2009 09:15 Go to previous message
James
> 3.5?
> James
Re: ctrl-c ctrl-v not working in 3.5 [message #575317 is a reply to message #11074] Thu, 16 July 2009 09:31 Go to previous message
Grant
working
> James
Eclipse
> > 3.5?
> > Thanks,
> > James
Re: ctrl-c ctrl-v not working in 3.5 [message #575362 is a reply to message #12453] Thu, 16 July 2009 13:14 Go to previous message
> step
> to
> Grant
> working
>> James
> Eclipse
>> > 3.5?
>> > Thanks,
>> > James
Previous Topic:ctrl-c ctrl-v not working in 3.5
Next Topic:Re: Drag and drop and cut, copy, paste between awt / swing and swt.
Current Time: Tue Nov 11 23:52:20 EST 2025
Powered by FUDForum. Page generated in 0.04527 seconds
