| Building nested projects [message #121073] |
Wed, 15 September 2004 11:12  |
Originally posted by: nigel.cook.gmail.com
I have a C++ project that I'm trying to build using the CDT plug-in.
The main project resides in ~/Main (just as an example). In that
directory, I have a makefile, a make.defs file that is included, and all
the subdirectors for includes, source, etc.
There is also a subdirectory that contains my CPPUnit test harness source.
Let's say ~/Main/Test. That directory contains the makefile for the test
executable, and also includes the make.defs file from above (include
../make.defs).
I don't ever build the Main executable, just the Test executable, in
~/Main/Test. I've tried creating a standard project from the makefile in
that directory, and that worked okay. However, for whatever reason it
couldn't 'discover' the source code from the Main project. The indexer
brings up a few thousand warnings.
Then I tried creating a new project from the ~/Main directory, but am
having difficulties building the makefile in the Test directory...I get a;
'No rule to make target 'Test/makefile.linux'. Stop.'
To me it doesn't matter which directory I start from, as long as I can
build the Test executable, and index the Main source headers.
Can I get either one of these approaches to work with the CDT?
| Re: Building nested projects [message #121277 is a reply to message #121173] |
Mon, 20 September 2004 09:58  |
> This plugin allows to build C/C++ projects with the SCons build tool. In
> order to use it you must install SCons first. I tested it with release
> 0.95, but it should work also with newer versions.
> Please let me know your opinions about the plugin.
Hi Lothar,
Looks really interesting, but the SCons requirement is a bit of an issue
for me. From what I gather looking at the FAQs that's a necessity. We have
10+ people using the same makefiles, so it's out of my hands.
Nigel
FUDForum. Page generated in 0.04748 seconds
