| custom component not displayed correctly [message #121044] |
Wed, 29 March 2006 04:26  |
Originally posted by: johannes.testori.NOSPAM_shark-soft.com
hi all,
i have created a component called "STRadioButtonSet" (that inherits from
my custom STPanel that inherits from JPanel).
the STRadioButtonSet has a method "addItem(String name)" that adds radio
buttons. every time a new item is added, a new radiobutton is created
internally and added to the STRadioButtonSet, and the layout might be
changed so the radiobuttons fit inside the STRadioButtonSet.
the problem is that when i create a new JPanel and place an
STRadioButtonSet inside it and add some radiobuttons with "addItem", the
radiobuttons are not displayed in the VE.
but if i create a new JFrame or JPanel and add the other panel (with the
STRadioButtonSet inside), the radiobuttons are displayed in the frame.
kind regards,
hannes
| Re: custom component not displayed correctly [message #121066 is a reply to message #121044] |
Wed, 29 March 2006 10:16  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
That is because when you are adding an STRadioButtonSet to the class
being edited we don't actually run the code. That is because the class
being edited has not been compiled yet, so we kind of interpret it.
Now to handle children visuals we can only handle these either through a
standard single value property setting (i.e. setAProperty(itsvalue);).
That is because we know what those are. Or we have added code into the
VE to understand what the add method is. For example we have code that
understands jpanel.add(child, layoutdata) to mean we are adding a child
to the jpanel. In your case it is just a method (addItem) and we don't
know anything about this. So we can't add your children.
Now the reason it shows when you add a JFrame that has an
STRadioButtonSet in it is because we do actually execute code of the
classes that we are not editing. So when you add that JFrame, we
actually create that JFrame using its constructor, so the true addItem
methods are called since it is compiled code.
Rich Kulp
| Re: custom component not displayed correctly [message #612380 is a reply to message #121044] |
Rich Kulp
FUDForum. Page generated in 0.04980 seconds
