Switching Perspective on tomcat server [message #121007] |
Sun, 08 February 2009 14:02  |
Originally posted by: popp.xxx.com
in my application I am switching perspectives between several views, i.e.
between the login view and a main view. It all works fine when I run the
application out of eclipse.
As soon as I deploy the application on the server, the switching doesn't
work, there just remains the first page. I also don't get any errors.
Has anybody any idea what might be the problem?
Thanks a lot in advance,
Daniel
Re: Switching Perspective on tomcat server [message #121234 is a reply to message #121007] |
Wed, 11 February 2009 06:59  |
Hi Daniel,
your description is rather vague. You are talking about "perspectives",
"views" and "pages" in the same context - could you clearify a little bit?
Here are some things to check
a) is everything you need in your build.properties?
b) are all bundles running in the application server? (-console and "ss"
command)
c) anything in the log? (start with -consolelog)
Greets
Benny
Daniel Popp wrote:
> i.e. between the login view and a main view. It all works fine when I
> run the application out of eclipse.
> Daniel
FUDForum. Page generated in 0.04059 seconds
