Home » Archived » Test and Performance Tools Platform (TPTP) » Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProcessExc
Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProcessExc [message #120985] Thu, 17 January 2008 03:08 Go to next message
I'm trying to execute JUnit tests as TPTP test. I'm using the internal
Agent Controller with tptp 4.4.0.3 along with eclipse 3.3.1.
But performing tests fails with an exception:
java.lang.RuntimeException:
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.handleException(TestExecutionHarnessExecutorStub.j ava:347)
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:434)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2098)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1830)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:750)
Caused by:
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:422)
... 4 more
!ENTRY org.eclipse.hyades.test.core 4 0 2008-01-17 08:56:22.151
!MESSAGE IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
During a debug session I figured out that
TestExecutionHarnessExecutorStub.waitForProcess() is being called with a
process id -1, which does not exist. Has someone experienced a similar
problem? How can I fix that?
Kind regards,
Stefan
Re: Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProces [message #121005 is a reply to message #120985] Thu, 17 January 2008 06:46 Go to previous messageGo to next message
Hi Stefan,
Are you converting the JUnit test classes to TPTP JUnit test suites
before running them? Also, how did you install TPTP 4.4.0.3, from a ZIP or
through Update Manager?
Paul
"Stefan Holzknecht" <s.holzknecht@intershop.de> wrote in message
news:fmn2dq$5ot$1@build.eclipse.org...
> Hello,
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by:
> at
> ... 4 more
> Kind regards,
> Stefan
Re: Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProces [message #121013 is a reply to message #121005] Thu, 17 January 2008 07:26 Go to previous messageGo to next message
Hi Paul,
I installed it from the ZIP file. The problem occures for 'Regular JUnit
Test's as well as for 'TPTP JUnit Test's. Actually I was able to run
tests, but when the problem occured it doesn't went away, even restarts,
or removing the deployment area did not help. Have you any hints what
I should check or verify? Are there some log files that might be
helpfull (does
eclipse\plugins\org.eclipse.tptp.platform.ac.win_ia32_4.4.1. v200709261752\agent_controller\config\servicelog.log
provide regarding information)?
Stefan
Paul Slauenwhite wrote:
> Hi Stefan,
> Paul
>> Hello,
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> ... 4 more
>> Kind regards,
>> Stefan
Re: Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProces [message #121022 is a reply to message #121013] Fri, 18 January 2008 06:33 Go to previous message
Hi Stefan,
Very strange. This behavior is usually caused by a bad test deployment,
usually not an issue when running a regular JUnit test suite. Can you
attach the following:
-IAC servicelog.log
-Eclipse .log
-Test suite
-Deployment files (*.deployment, *.artifact, *.location).
In the meantime, can you try with the stand-alone Agent Controller?
Paul
news:fmnhh6$a4p$1@build.eclipse.org...
> Hi Paul,
> or removing the deployment area did not help. Have you any hints what I
> should check or verify? Are there some log files that might be helpfull
> (does
> Stefan
>> Hi Stefan,
>> or through Update Manager?
>> Paul
>>> Hello,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> ... 4 more
>>> Kind regards,
>>> Stefan
Previous Topic:Unable to profile using Agent Controller
Next Topic:How to know full list of TPTP Profiler features.
Current Time: Thu Oct 16 21:10:49 EDT 2025
Powered by FUDForum. Page generated in 0.03504 seconds
