Home » Newcomers » Newcomers » starting up eclipse on fedora
starting up eclipse on fedora [message #120962] Wed, 30 November 2005 17:52 Go to next message
Originally posted by: peter.buil.home.nl
I have strange problem during startup of eclipse. Just after the startup i
get the following nessage:
"could not create intro part", and a empty reason. I can't figure out what
is going on. I've scanned the newcomer questions as it seems to be a
newcomer problem. But .. nothing.
Does someone have a clue?
Re: starting up eclipse on fedora [message #121033 is a reply to message #120962] Thu, 01 December 2005 03:24 Go to previous messageGo to next message
Originally posted by: radoslawg.xxxxxxxxxxxx.xxx
> i get the following nessage:
> what is going on. I've scanned the newcomer questions as it seems to be
> a newcomer problem. But .. nothing.
This is totally, absolutely wild guess as I am not specialist on this in
any way but do you have mozilla installed?
Radek.
Re: starting up eclipse on fedora [message #121080 is a reply to message #120962] Thu, 01 December 2005 07:22 Go to previous messageGo to next message
You're getting the "could not create intro part" error because you're
using the default java environment installed with Fedora (GCJ) rather
than a Java runtime from Sun or IBM. Install Java 1.4.1 or later, make
sure it shows up first on the path, and eclipse should run properly.
Hope this helps,
- Jeff
Re: starting up eclipse on fedora [message #121112 is a reply to message #121080] Thu, 01 December 2005 13:40 Go to previous messageGo to next message
Before using eclipse ie downloaded the 1.4.2-10 jdk (rpm.bin) and
installed it as described. I also added the JAVA_HOME to my bash_profile.
Is that not enough?
Re: starting up eclipse on fedora [message #121117 is a reply to message #121080] Thu, 01 December 2005 13:48 Go to previous messageGo to next message
Thanks Jeff,
You were rigth. I changed the order in the path and everything runs as it
should.
cheers peter
Re: starting up eclipse on fedora [message #125569 is a reply to message #121117] Thu, 22 December 2005 14:51 Go to previous message
I thought it might be worth it to note that I am seeing the same issue
with jrockit-j2sdk1.4.2_08. I switch to the Sun JDK and it works fine.
Previous Topic:NoClassDefFound - BundleURLConnection
Next Topic:restarting after loading in updates...
Current Time: Mon Jul 07 00:29:02 EDT 2025
Powered by FUDForum. Page generated in 0.09399 seconds
