Send to back for labels of side affixed symbols [message #120932] |
Fri, 20 April 2007 03:38 |
--------------080408050300040206050902
I noticed that labels from side affixed symbols cannot be arranged with
the Format->Order commands. Instead there is a "Snap back" command which
puts the label completely into the background. After having issued that
command, how do I get the label back into the foreground ? And is there
any other way to arrange the labels along with the "parent" symbols ?
To illustrate this, see the attached image. The gray rectangle with the
side affixed port symbol is in the background of the white rectangle.
The upper left label of the port on the gray rectangle should be in the
same level of z ordering as its symbol (the port itself is hidden if I
move the gray rectangle completely behind the white rectangle).
Could this be considered to be a bug ?
Armin
Content-Type: image/png;
name="stacked-labels.png"
Content-Disposition: inline;
filename="stacked-labels.png"
iVBORw0KGgoAAAANSUhEUgAAALsAAABKCAIAAABsPLKBAAAAK3RFWHRDcmVh dGlvbiBUaW1l
AEZyIDIwIEFwciAyMDA3IDA5OjMwOjU4ICswMTAwDhPKKQAAAAd0SU1FB9cE FAcfIvRhucAA
AAAJcEhZcwAACxIAAAsSAdLdfvwAAAAEZ0FNQQAAsY8L/GEFAAADVUlEQVR4 2u2dwXWrMBBF
kY+XXrgU0oFL8uLv49+BS0kJ/ArsTrJIAYTz5egoAoQeCI0E7y4SWTBiEI+R DJpEte2tGkGp
W9M0VVoul0vbtokPSsI5SDtACuOof729fTyfz/7m7o53auq6vt/v0m4TMV6K 6eQSOBYopaR9
JpJwVCIYVAzBoGIIBhVDMA5KvUv7QEqCMYZgHNr2r7QPpCQYY3Ik54deR2kH 4uB0cco3U/ah
9/BGbCOKqX5fre4qprl4zoGSHVeQ+aOSfuV0+cHZ1K8PL6v/mEpdtiuhoK0s nDYny2OGTqXB
yMXZaqzsZvsNDlrNOOVVWRRjugtslkOYsl3Z/zjZmlntYN+vs+/d2THAY7gk kAy2E6vxNLxi
zPl8VmF0expjaPWMVkNlKaMK1pPTicv7tGvB3NxOGXJG2w5GiJAT8Z8O6lga XjHm8/Pa35Z+
RZUZlWbYRp+BBrrBeYwkWqDtD5BtaxHFmfY30n2TC0kVowcjLQu7PIjnFo8y DdQxX0vBLkNH
DPFkibeTjqVn6czXlM21N3MUp34SY6i7OEo3mamA+RjXcGw3u94uD+5c1hMd NXtlePiXIIgN
rwwfjBaTISS3GJPXPIY45CaXaoli0iemlA701TpkqwiMMQSDiiEYVAzBoGII BhVDMKgYgiG5
oup6vQ4me/cfq9d1/Xg8BF0lBknFMNm7RDgqEQwqhmBQMQSDiiEY3YxS5l1X 0/wLX9iQ4Svc
3cIYQzCOnrxrkb+1STLH9zzmdDr1/3Ii2TAho79PMV9ff1b275a8T6Kfwu7y vbeTdy3F3vK9
y5v5+hOVV02xZr53VWiMmcxerpDbbo0U66ycCemx8MYlFaOTvQP3tD9CHWeS xPo/Q2xnH3dV
Z9A8rBn53mOOSSpmLNk7/cO6Je/G95bvXeSoFJ0l3R39UmX+dLu8me8MoqRY V5GW6ZSe711k
jJlMda5WSLGG2HC+d5GK8fRjiEl/t8CJYaChlDOexhe2abOLUYmgeMbK8hST +cQwQ+Lme5en
GCILFUMwqBiCQcUQDCqGYFAxBIOKIRhUDMGgYggGFUMwqBiCQcUQDCqGYFAx BIOKIRjZrcEL
T0khIvj+Ww4hfTgqEQwqhmBQMQSDiiEYVAzB+Aa7Ho1cGTPNowAAAABJRU5E rkJggg==
--------------080408050300040206050902--
FUDForum. Page generated in 0.03155 seconds
