FTP support [message #120909] |
Wed, 30 November 2005 14:49  |
Originally posted by: markus.freyt.gmail.com
Hi there,
I have installed Eclipse SDK,Version: 3.1.1,Build id: M20050929-0840 and
Java(TM) 2 Runtime Environment, Standard Edition,Version 1.4.2 on my local
machine. I'm quiet happy, but I would like to sync with my webserver via
FTP or SFTP. DonT need version control.
I found out, that Team Synchronization with Klomp SFTP might help me. I
have installed Subclipse 0.9.37 and also Eclipse FTP and WebDAV Support
3.0.0.
When opening the view "Synchronize" the followin error message appears "An
error occurred. See error log for details." After pressing ok the dialog
box for choosing the connection type appears, but of course when choosing
one entry the same error message occurres again.
The error log of my Windows 2000 machine is saying: "The server could not
bind to the transport \Device\NetbiosSmb because another computer on the
network has the same name. The server could not start. "
What could be the problem. Let me know, if you need more information...
Thanks...
Markus
Re: FTP support [message #121767 is a reply to message #121479] |
Mon, 05 December 2005 11:32  |
Originally posted by: markus.freyt.web.de
Finally I have found the solution by myself. :-) It was just an issue with
version numbers for some pluins. For some reason 3.1.0 was installed,
mixed with other plugins in vers. 3.1.1. Solution was to download FTP and
WEBDAV support in version 3.1.1 from the original eclipse site.
Cheers.
Markus
FUDForum. Page generated in 0.09136 seconds
