Home » Language IDEs » ServerTools (WTP) » EL support in JSTL 1.2 taglibs - bug?
EL support in JSTL 1.2 taglibs - bug? [message #120795] Thu, 14 July 2005 08:48 Go to next message
There appears to be a bug in the JSP editor/validator relating to scoped
variables referenced in JSTL 1.2 tags using dot notation. I am using the
rlease version of Eclipse 3.1 with WTP 0.7M5 and associated dependancies,
and the latest JSTL standard tag library from Jakarta (v1.1.2)
Examples:
1/. The following works as it should in the main body of the JSP:
${sessionScope.testVar}
2/. The following raises a validation error, although it is valid syntax
<c:if test='${sessionScope.testVar=="hello"}'>
<%--do something--%>
</c:if>
Error: The method getTestVar() is undefined for the type Map
3/. However the following also works correctly:
<c:if test='${sessionScope["testVar"]=="hello"}'>
</c:if>
When published to a server (Tomcat 5.5), all of these work OK, but only
two of them pass the validation and syntax checking tests.
Re: EL support in JSTL 1.2 taglibs - bug? [message #120881 is a reply to message #120795] Thu, 14 July 2005 12:54 Go to previous messageGo to next message
Is Tomcat 5.5 the targetted server for the project as well?
- Nitin
Re: EL support in JSTL 1.2 taglibs - bug? [message #121004 is a reply to message #120881] Fri, 15 July 2005 05:04 Go to previous messageGo to next message
Yes - I used the same local installation of Tomcat to get the runtime
configuration - and this is also the server to which the project is
published
Tomcat 5.5.9 with the JDK 1.4 compatbility patch
Note that the project runs OK on the server - I have to disable the JSP
validation in Eclipse to avoid the parse errors, and then
publishing/runnning works OK.
Re: EL support in JSTL 1.2 taglibs - bug? [message #121023 is a reply to message #120795] Fri, 15 July 2005 05:42 Go to previous message
I have checked that this problem remains in the latest WTP version (WTP
0.7RC1)
I have submitted this as a bug report (103980)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=103980
Previous Topic:Generic Servers
Next Topic:How to config DB link with charset support?
Current Time: Mon Nov 17 12:52:02 EST 2025
Powered by FUDForum. Page generated in 0.04296 seconds
