Home » Eclipse Projects » Remote Application Platform (RAP) » TextSizeDeterminationHandler sets and resets the size of a widget
TextSizeDeterminationHandler sets and resets the size of a widget [message #120721] Fri, 06 February 2009 07:29 Go to next message
in method TextSizeDeterminationHandler.afterPhase, there's the following
code:
WidgetTreeVisitor.accept( shells[ i ], saveSCOrigins );
WidgetTreeVisitor.accept( shells[ i ], clearLayout );
shells[ i ].setSize( buffer.x + 1000, buffer.y + 1000 );
shells[ i ].setSize( buffer );
WidgetTreeVisitor.accept( shells[ i ], restoreSCOrigins );
Why setting size buffer+1000 and then reset to buffer?
Is needed to calculate something?
If yes, can I avoid this "adjusting"?
Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #120862 is a reply to message #120721] Fri, 06 February 2009 09:09 Go to previous messageGo to next message
Hi Enrico,
you discovered one of the pieces of magic in RAP ;-)
This code triggers a resize of all widgets after the results of the text
measurements arrive from the client. As the layout is already done
before (with estimated text sizes), we need to trigger a re-calculation
of widget's preferred sizes at this point.
This trick turned out to work rather well, that's why it's still there.
In which respect does it hurt in your case?
Best regards, Ralf
Enrico Zanaga wrote:
> code:
> Thanks
> Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #120905 is a reply to message #120862] Fri, 06 February 2009 09:48 Go to previous messageGo to next message
Hi Ralf,
in my application every table has a custom column auto size algorithm.
The first time a table is shown, the columns spreads to the 100% of
table's width. When the table's width increase the columns' width
increase too, spreading to 100%. When the table's width decrease, the
columns' width don't decrease.
This algorithm works in SWT, but in RWT when I open a shell with a table
the columns go directly out of the table, because "setSize( buffer.x +
1000, buffer.y + 1000 )" increase the table's width. The result is
having a table with columns so large that's not visible.
Example in SWT:
+-- Shell ----------+
|+Col1----+Col2-+C3+|
||________|_____|__||
Example in RWT:
|+Col1------------+Col2------+C3--+
||________________|_|________|____|
In this case I wish to disable the TextSizeDeterminationHandler, perhaps
setting manually some properties in the control...
Have any ideas or hints?
Enrico
Ralf Sternberg ha scritto:
> Hi Enrico,
> Best regards, Ralf
>> code:
>> Thanks
>> Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #120948 is a reply to message #120905] Fri, 06 February 2009 11:39 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
Enrico,
you wondering, have you tried using the TableColumnLayout?
It does automatically resize columns based on weights (i.e. 10/5/5 ->
50%, 25%, 25%) and works well with RAP too.
Here's a snippet:
http://eclipsenuggets.blogspot.com/2007/11/one-of-less-promi nent-novelties-in.html
Elias.
have you looked into the TableColumnLayout lay
> Hi Ralf,
> Example in SWT:
> ||________|_____|__||
> Example in RWT:
> Thanks
> Enrico
>> Hi Enrico,
>> Best regards, Ralf
>>> Hi,
>>> code:
>>> Thanks
>>> Enrico
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #120963 is a reply to message #120905] Fri, 06 February 2009 11:52 Go to previous messageGo to next message
Hi Enrico,
I understand your case but I'm afraid there is currently no cure for it
(unless you find some hack on your side ;-). Calculating layouts
depending on previous states is not common, thus we didn't expect such a
case.
Best regards, Ralf
> Hi Ralf,
> Example in SWT:
> ||________|_____|__||
> Example in RWT:
> Thanks
> Enrico
>> Hi Enrico,
>> Best regards, Ralf
>>> Hi,
>>> code:
>>> Thanks
>>> Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #121070 is a reply to message #120963] Mon, 09 February 2009 12:32 Go to previous messageGo to next message
We ran into the same problems with our resize listeners. We were getting
weird results due to the spurious resize events, not to mention the
flicker problems. Our solution was to create a custom resize listener that
we call WellBehavedControlAdapter. It tracks the previous size of the
control's shell and detects the resize events caused by the
TextSizeDetermination. Below is the code for those that are interested.
Cole
=== Begin WellBehavedControlAdapter.java ===
public abstract class WellBehavedControlAdapter extends ControlAdapter
public void controlResized(ControlEvent e)
Shell shell = ((Control)e.widget).getShell();
Point shellSize = shell.getSize();
Point previousSize =
(Point)e.widget.getData("previousShellSize"+this.hashCode());
e.widget.setData("previousShellSize"+this.hashCode(), shellSize);
if(previousSize != null){
int dx = Math.abs(Math.abs(shellSize.x - previousSize.x) - 1000);
int dy = Math.abs(Math.abs(shellSize.y - previousSize.y) - 1000);
if((dx <= 2 || dy <= 2)){
// This came from the TextSizeDetermination
return;
handleControlResized(e);
protected abstract void handleControlResized(ControlEvent e);
=== End WellBehavedControlAdapter.java ===
Ralf Sternberg wrote:
> Hi Enrico,
> case.
> Best regards, Ralf
>> Hi Ralf,
>> Example in SWT:
>> ||________|_____|__||
>> Example in RWT:
>> Thanks
>> Enrico
>>> Hi Enrico,
>>> Best regards, Ralf
>>>> Hi,
>>>> code:
>>>> Thanks
>>>> Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #121102 is a reply to message #120862] Tue, 10 February 2009 03:33 Go to previous messageGo to next message
Hi Ralf,
the problem with this piece of magic is that it triggers additional
Resize-Events which results in different behaviour between SWT and RWT
(see https://bugs.eclipse.org/bugs/show_bug.cgi?id=231751).
Why doesn't a Shell#layout(true, true) work, instead?
Stefan.
Ralf Sternberg schrieb:
> Hi Enrico,
> Best regards, Ralf
>> code:
>> Thanks
>> Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #121169 is a reply to message #121070] Wed, 11 February 2009 04:09 Go to previous messageGo to next message
Hi Cole,
> that we call WellBehavedControlAdapter. It tracks the previous size of
> the control's shell and detects the resize events caused by the
I'm sorry to hear about those ugly hacks being necessary. As Stefan
pointed out, there is already a bug for the resize events problem. Feel
free to vote and comment on this one.
Unfortunately, the problem isn't trivial. The text size determination
gets the result when the layout is already done, so we need to trigger a
re-layout. I'm afraid we'll have to live with that until someone comes
up with an improvement that does not involve regressions in some other
cases.
Ralf
> @Override
> return;
>> Hi Enrico,
>> case.
>> Best regards, Ralf
>>> Hi Ralf,
>>> Example in SWT:
>>> ||________|_____|__||
>>> Example in RWT:
>>> Thanks
>>> Enrico
>>>> Hi Enrico,
>>>> text
>>>> Best regards, Ralf
>>>>> Hi,
>>>>> following
>>>>> code:
>>>>> Thanks
>>>>> Enrico
Re: TextSizeDeterminationHandler sets and resets the size of a widget [message #121196 is a reply to message #121102] Wed, 11 February 2009 04:55 Go to previous message
Hi Stefan,
just to make this clear: the smiley was meant to indicate that we're not
really proud of this "magic". Actually, I don't think that magic is ever
a good thing in software design.
As Rüdiger pointed out in the bug, there is code around that does the
layout based on resize events. This would not work anymore.
Ralf
>> Hi Enrico,
>> Best regards, Ralf
>>> Hi,
>>> code:
>>> Thanks
>>> Enrico
Previous Topic:Focus rectangle always visible in Opera
Next Topic:Handle return key as tab key
Current Time: Thu Nov 06 11:01:17 EST 2025
Powered by FUDForum. Page generated in 0.03977 seconds
