Home » Eclipse Projects » Equinox » Equinox command line vs Equinox Eclipse - Classpath issues.
Equinox command line vs Equinox Eclipse - Classpath issues. [message #120684] Tue, 04 November 2008 11:05 Go to next message
Gents,
I am having an issue running a packaged jar inside an equinox osgi prompt.
I have all of the dependencies solved and when checking the status of the
bundles, it says "Resolved", though when I run it I get a
NoClassDefFoundError.
When running the same project that the jar is based from inside Eclipse,
everything goes fine.
I have been through a few troubleshooting steps, like checking the
bundle-Classpath - making sure it matches the projects classpath before
jarring.
I would believe there is some quirky, simple thing I have missed in this
equation, an help is appreciated.
A link to the error, http://pastebin.com/m36b44de0
-Shaun
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120696 is a reply to message #120684] Tue, 04 November 2008 11:24 Go to previous messageGo to next message
Are you using Export --> Deployable plug-ins and fragments to create the
bundle?
I'd also crack open the jar and take a look.
If that's not it could you post your manifest and the rough layout of your
bundle.
-Simon
"Shaun Galey" <sgaley343gs@yahoo.com> wrote in message
news:95af702f3c3f5b93ddbb97ba385eafd7$1@www.eclipse.org...
> Gents,
> jarring.
> -Shaun
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120704 is a reply to message #120696] Tue, 04 November 2008 11:36 Go to previous messageGo to next message
Simon,
I just tried exporting with your advice - Deployable Plugins and
Fragments, same issues.
I have cracked open the jar and the .class and .java files are inside of
it in the correct location.
Manifest.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Db Plug-in
Bundle-SymbolicName: qq.mob.db;singleton:=true
Bundle-Version: 0.0.4
Bundle-Activator: qq.mob.db.Activator
Require-Bundle: Jama;bundle-version="1.0.0",
org.apache.log4j,
org.apache.collections;bundle-version="3.2.0",
org.eclipse.core.runtime,
org.eclipse.core.resources,
org.jfree.chart,
qq.mob.scenario,
qq.mob.common;bundle-version="1.0.0",
qq.mob.utility;bundle-version="1.0.0"
Bundle-ActivationPolicy: lazy
Export-Package: org.hibernate,
org.hibernate.criterion,
qq.epi.disease,
qq.epi.model,
qq.mob.db,
qq.mob.db.itrf,
qq.mob.model,
qq.mob.ref,
qq.mob.util
Bundle-ClassPath: .,
lib/antlr-2.7.6.jar,
lib/asm.jar,
lib/asm-attrs.jar,
lib/c3p0-0.9.1.jar,
lib/cglib-2.1.3.jar,
lib/commons-logging-1.0.4.jar,
lib/dom4j-1.6.1.jar,
lib/ejb3-persistence.jar,
lib/hibernate3.jar,
lib/hibernate-annotations.jar,
lib/hibernate-commons-annotations.jar,
lib/jta.jar,
lib/log4j-1.2.11.jar,
lib/mysql-connector-java-3.1.12-bin.jar,
conf/,
lib/Jama-1.0.2.jar
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Import-Package: org.osgi.framework;version="1.3.0"
Photo of the project structure.
http://img261.imageshack.us/my.php?image=imageschackkc5.png
-Shaun
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120710 is a reply to message #120704] Tue, 04 November 2008 15:51 Go to previous messageGo to next message
Hmm... from what you describe structurally it sounds ok.
I suspect the CNF is a nested exception based on another class needed to
define your activator.
One difference when running stand-alone vs. in the IDE is the value of:
org.osgi.framework.bootdelegation
A bundle should import "all" non-java.* packages it uses and at a glance it
appears you're not.
To narrow down the problem try setting "org.osgi.framework.bootdelegation=*"
-Simon
news:163a26380abed8b8b120213d009c1038$1@www.eclipse.org...
> Simon,
> Manifest.MF
> org.apache.log4j,
> org.jfree.chart,
> qq.mob.scenario,
> qq.epi.disease,
> qq.epi.model,
> qq.mob.db,
> qq.mob.db.itrf,
> qq.mob.model,
> qq.mob.ref,
> qq.mob.util
> lib/asm.jar,
> lib/asm-attrs.jar,
> lib/c3p0-0.9.1.jar,
> lib/hibernate3.jar,
> lib/jta.jar,
> conf/,
> lib/Jama-1.0.2.jar
> -Shaun
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120717 is a reply to message #120710] Tue, 04 November 2008 17:31 Go to previous messageGo to next message
Simon,
I inserted osgi.java.profile.bootdelegation=* into my config.ini file and
I see no difference.
I placed some System.outs into the Activator before and after the
DBServiceFactory call and also inside DBServiceFactory.
I receive the System.outs from before the Servicefactory call and not
after, as expected. I don't get any outs from within servicefactory though.
I am not sure of how to proceed, thank you for your help.
-Shaun
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120724 is a reply to message #120717] Tue, 04 November 2008 18:06 Go to previous messageGo to next message
Use org.osgi.framework.bootdelegation=*
osgi.java.profile.bootdelegation is a different property
news:ee905c1024c3557ceab2609894400fde$1@www.eclipse.org...
> Simon,
> though.
> -Shaun
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120730 is a reply to message #120724] Tue, 04 November 2008 18:23 Go to previous messageGo to next message
Thank you Simon, you are the man.
I appreciate all the help you gave me, bootdelegation fixed it.
-Shaum
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120736 is a reply to message #120730] Tue, 04 November 2008 18:57 Go to previous messageGo to next message
That's great.
Also see http://wiki.eclipse.org/Equinox_Boot_Delegation
What you have might work for you but it would be better to explicitly
declare your imports as it does impact performance and
modularity/portability.
-Simon
news:5000a71041fff3dbb39612f3d6db14dc$1@www.eclipse.org...
> -Shaum
Re: Equinox command line vs Equinox Eclipse - Classpath issues. [message #120747 is a reply to message #120736] Wed, 05 November 2008 12:48 Go to previous message
Simon,
I would like to explicitly declare them, but I don't know what imports the
bootdelegation is calling.
Could you give me a list or and idea of where to look to get those jars?
-Shaum
Simon Kaegi wrote:
> That's great.
> -Simon
>> -Shaum
Previous Topic:p2-self provisioning into emty folder or assembled product?
Next Topic:p2 works... the second time
Current Time: Sun Oct 19 22:15:03 EDT 2025
Powered by FUDForum. Page generated in 0.05104 seconds
