Home » Language IDEs » Java Development Tools (JDT) » can't install PDE Junit plugin
can't install PDE Junit plugin [message #120627] Mon, 24 November 2003 23:04 Go to next message
Originally posted by: eipe.uiuc.edu
I was following along with 'Contributing to Eclipse' by Erich Gamma and Kent
Beck, chapter 12, page 93. I was trying to install the PDE JUnit plugin.
After downloading it and unzipping it into the plugins folder, I'm not quite
sure how to 'install' it. After trying a few things, the extra menu item
under 'Run as' still doesn't show up (which is supposed to happen).
Has anybody had this problem? Or something similar with general installation
of plugins? I've installed plugins before - the CDT for example - and had no
trouble.
Rohit Eipe
Re: can't install PDE Junit plugin [message #120642 is a reply to message #120627] Mon, 24 November 2003 23:15 Go to previous messageGo to next message
You did restart Eclipse?
Darins
"Rohit Eipe" <eipe@uiuc.edu> wrote in message
news:bpuk7p$779$1@eclipse.org...
> Hi
Kent
quite
installation
no
> trouble.
> Thanks
> Rohit Eipe
Re: can't install PDE Junit plugin [message #120686 is a reply to message #120642] Tue, 25 November 2003 00:49 Go to previous messageGo to next message
Originally posted by: draganch.uiuc.edu
Yes, we did. I was even able to import the binary into my workspace. But the
feature's manifest (which I also imported) gives the following warning:
Plug-in reference 'org.eclipse.pde.junit' cannot be resolved. feature.xml
org.eclipse.pde.junitfeature-feature line 39
Julia
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bpukr7$7le$1@eclipse.org...
> Darins
> > Hi
> Kent
> quite
> installation
had
> no
> > trouble.
> > Thanks
> > Rohit Eipe
Re: can't install PDE Junit plugin [message #121631 is a reply to message #120686] Tue, 25 November 2003 06:52 Go to previous messageGo to next message
Originally posted by: thomas_maeder.ch.ibm.com
Which eclipse build are you using? The PDE junit plugin wasn't in
earlier builds
Thomas
> Julia
>>Darins
>>>Hi
>>Kent
>>quite
>>installation
> had
>>no
>>>trouble.
>>>Thanks
>>>Rohit Eipe
Re: can't install PDE Junit plugin [message #121783 is a reply to message #121631] Tue, 25 November 2003 12:41 Go to previous message
Eclipse 2.1.1, build id 200306271545
I tried PDE JUnit versions 2.1.5 and 3.0.0. None of them show up in the
Plugin Details in the About box.
Julia
"Thomas M
Previous Topic:[bug] M5: refactoring anon -> nested class
Next Topic:www.myeclipseide.com ?
Current Time: Fri Oct 31 01:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.45274 seconds
