Home » Modeling » GMF (Graphical Modeling Framework) » Getting back model elements
Getting back model elements [message #120625] Thu, 19 April 2007 06:20 Go to next message
Originally posted by: bagnard.natacha.free.fr
I'm new to GMF and I'm trying to find how to get back my model elements
because I want to know how many instances of each one I've already made
and be able to get attributes values for each too.
I use the modelFactory for create them, but it has no methods to get
them back ... And I haven't find where it is.
Does someone know how I could do that ?
Natacha
Re: Getting back model elements [message #120638 is a reply to message #120625] Thu, 19 April 2007 06:34 Go to previous messageGo to next message
Originally posted by: evaandoli.dodo.com.au
So can I guess:-
When you create a 'Node' on the diagram you wish to see what other objects
have been created and set certain attributes depending on what you find ?
is that about right ?
If so then.
Try looking at subclasses of
CreateElementCommand
you could override method
doDefaultElementCreation()
As at this point you have the container class.
A cleaner way and maybe the one I prefer is if you new Node been to
interrigate the top level container class then make it a reference in your
object model and after the node is created you can play with it until you
have what you want.
Hope that helps a little,
Stu
"natch" <bagnard.natacha@free.fr> wrote in message
news:f07fnb$qiu$1@build.eclipse.org...
> I use the modelFactory for create them, but it has no methods to get them
> Natacha
Re: Getting back model elements [message #120743 is a reply to message #120638] Thu, 19 April 2007 09:16 Go to previous messageGo to next message
Stu a écrit :
> So can I guess:-
It's nearly the same. I create new element at the plugin start.
I do it this way :
/** Model Initialisation **/
MyElement elem = DataModelFactory.eINSTANCE.createMyElement();
This element can't be create graphically on the diagram but is linked to
a diagramElement.
So when, I create a diagram element I want that I could do
diagramElement.setMyElement(elem).But I need to get elem back ...
> If so then.
I don't know how to use this container class to get my elements. I've
try tu use DataModelPackage.eINSTANCE.eContainer but I haven't success
to find my elements with it.
> have what you want.
So only way I've find now is to store lists for each element of my model
and then add them to those list when I call a createElement method. I'm
sure those elements are already store somewhere, but I didn't understand
how to use container to get it.
> Stu
Re: Getting back model elements [message #121001 is a reply to message #120743] Fri, 20 April 2007 10:55 Go to previous message
Hello !
I have the same problem. I would like to be able to get all the
instances of all classes implemented (even if they have not graphical
representation). To create instances I use factory, but does soemeone
can explain me which class i have to use to get its back?
Julien
Previous Topic:Using GMF to displaying Charts (bar chart and Pie chart)
Next Topic:Problems with integration of GMF Editor into a RCP Application
Current Time: Tue Jul 22 19:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.03859 seconds
