Home » Language IDEs » ServerTools (WTP) » Eclipse 3.1 Web Standard Tools not working
Eclipse 3.1 Web Standard Tools not working [message #120623] Wed, 13 July 2005 21:27 Go to next message
Originally posted by: melrosenberg.charter.net
My environment is:
Eclipse project sdk 3.1.0
EMF SDK 2.1.0
Graphical Editing Framework SDK 3.1.0
Visual Editor SDK 1.0.2.1
Web Standard Tools Feature 0.7.0
It wont regognize xml files, do syntax highlighting or syntax verification.
Is there a way to fix this?
Re: Eclipse 3.1 Web Standard Tools not working [message #120767 is a reply to message #120623] Thu, 14 July 2005 05:27 Go to previous messageGo to next message
Mel Rosenberg wrote:
> My environment is:
> EMF SDK 2.1.0
You need to upgrade the VE SDK to a version that matches/includes
the correct version of JEM:
http://www.eclipse.org/downloads/download.php?file=/tools/ve /downloads/drops/I-I20050623-200506231440/VE-SDK-I20050623.z ip
Additionally, have you restarted Eclipse with the "-clean" argument?
- Nitin
Re: Eclipse 3.1 Web Standard Tools not working [message #121954 is a reply to message #120623] Mon, 18 July 2005 14:16 Go to previous messageGo to next message
On Wed, 13 Jul 2005 21:27:54 -0400, Mel Rosenberg <melrosenberg@charter.net> wrote:
> My environment is:
> EMF SDK 2.1.0
Not sure, you might track down if the version of JEM that comes with VE 1.0.2.1 is compatible
with the version we require, but would be surpised that'd effect highlighting, etc.
If you can not get to work on a recent build, such as RC1, please open a bug, and
attach a sample of the file you are trying to edit, and your configuration and .log files.
(This later two available from the "help ... about" box).
Re: Eclipse 3.1 Web Standard Tools not working [message #122095 is a reply to message #120623] Mon, 18 July 2005 21:01 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Do you have any other XML editors installed? If so, this is a symptom of
an editor conflict.
Bob Foster
http://xmlbuddy.com/
> My environment is:
> EMF SDK 2.1.0
Re: Eclipse 3.1 Web Standard Tools not working [message #122974 is a reply to message #121954] Tue, 19 July 2005 09:21 Go to previous messageGo to next message
> highlighting, etc.
It is not. You need VE 1.1 for WTP 0.7, else no XML Editor shows up.
Stefan
Re: Eclipse 3.1 Web Standard Tools not working [message #125041 is a reply to message #120767] Fri, 22 July 2005 21:01 Go to previous messageGo to next message
I have tried your suggestions and upgraded. My configuration is now:
EMF SDK 2.1.0
Visual Editor SDK 1. 1.0
Web Standard Tools Feature 0.7.0 (RC1)
WTP EMF Integration Core 1.0.1.2
I have done a restart with -clean a couple of times.
Attached are the platform details and log files.
I am still not able to get any xml highlights or verification.
Any help would be appreciated.
thanks
Mel
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:db5b61$mop$1@news.eclipse.org...
> > My environment is:
> > EMF SDK 2.1.0
verification.
/I-I20050623-200506231440/VE-SDK-I20050623.zip
> - Nitin
Re: Eclipse 3.1 Web Standard Tools not working [message #125223 is a reply to message #125041] Sat, 23 July 2005 18:48 Go to previous messageGo to next message
Mel,
From reading your .log, I'm seeing a lot of errors from the
org.vssplugin plugin as well as some odd EMF errors that indicate
mismatched versions of EMF (or possibly parts of VE/JEM) at runtime.
You might want to remove the old VE, JEM, and EMF versions you
still have installed and restart with -clean to see if it makes a
difference. I'm not sure the XML UI plugin was starting properly
and this could be because of odd dependency problems with the
multiple versions you have installed.
Additionally, you shouldn't need the Sysdeo Tomcat plugin if you
install the full WTP instead of just the WST part. The JST (J2EE
Standard Tools) included can launch and debug Tomcat and many other
kinds of servers.
- Nitin
Re: Eclipse 3.1 Web Standard Tools not working [message #125512 is a reply to message #125223] Mon, 25 July 2005 10:36 Go to previous messageGo to next message
Originally posted by: michael.giroux.objectweb.org
FWIW, I have found that -clean alone does not provide a complete solution.
As I have moved forward with WTP milestones, and release candidates and
installed the newer versions of GEF, EMF, JEM, I have had to do the
following:
1. stop eclipse
2. install new versions of projects
3. remove old versions
4. eclipse -initialize
5. eclipse -clean
If I fail to remove old versions, and/or fail to -initialize eclipse seems
to get confused by the older versions.
It seems to me that -clean isn't doing as much as it needs to do to clean up
the environment when plugins are updated, but I have no basis for this other
than observation.
Michael Giroux
Re: Eclipse 3.1 Web Standard Tools not working [message #125670 is a reply to message #125512] Mon, 25 July 2005 21:34 Go to previous messageGo to next message
I liked your thought. So I went one better. I removed eclipse, all of it.
I deleted all the files under .metadata and even removed all the '.' files
(ie.. .classpath, .project, ...) from my project.
Then I reinstalled:
Eclipse 3.1
emf-sdo-xsd-SDK2.1.0
GEF-SDK-3.1
JEM-SDK-1.1
wtp-wst-sdk0.7C3
I then started Eclipse and found the error log to be empty. I have attached
the Platform Details.
My problems are:
JSP pages are not recognized, all I get it a text editor.
Under Preferences -> Installed Runtimes -> Add, I don't get any servers to
configure.
I also don't have the option to create a J2EE project.
Did I not install the correct items?
Any help would be greatly appreciated.
"Michael Giroux" <michael.giroux@objectweb.org> wrote in message
news:dc2td6$gfc$1@news.eclipse.org...
> following:
> 1. stop eclipse
> 5. eclipse -clean
up
other
> than observation.
> Michael Giroux
Re: Eclipse 3.1 Web Standard Tools not working [message #125709 is a reply to message #125670] Mon, 25 July 2005 22:11 Go to previous messageGo to next message
> Then I reinstalled:
> Eclipse 3.1
> GEF-SDK-3.1
> JEM-SDK-1.1
> wtp-wst-sdk0.7C3
> My problems are:
> configure.
The JSP editor is part of the J2EE Standard Tools (JST) which you
can find in the full WTP downloads (the Web Standard Tools are
included as well), "wtp-sdk" or just "wtp" _instead_ of the wtp-wst
downloads.
The corresponding file for what you already have would be
wtp-sdk-0.7RC3.zip.
- Nitin
Re: Eclipse 3.1 Web Standard Tools not working [message #126185 is a reply to message #125709] Tue, 26 July 2005 22:49 Go to previous message
Many thanks!!! It worked.
news:dc4653$q98$1@news.eclipse.org...
> > Then I reinstalled:
> > Eclipse 3.1
> > GEF-SDK-3.1
> > JEM-SDK-1.1
> > wtp-wst-sdk0.7C3
attached
> > My problems are:
to
> > configure.
> downloads.
> wtp-sdk-0.7RC3.zip.
> - Nitin
Previous Topic:Setting the deploy scope to Application
Next Topic:Re: Where did the J2EE perspecitve go in wtp-0.7rc3 ??
Current Time: Fri Jul 25 04:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.26220 seconds
