Home » Archived » BIRT » MULTIPLE DATA SETS
MULTIPLE DATA SETS [message #120605] Mon, 30 January 2006 22:18 Go to next message
Originally posted by: ARASH.BARIRANI.VERIZONWIRELESS.COM
Is it possible to pull in data from a different data source inside one's
select/query call? For example in Oracle:
"create table a as
select a, b, c from table_2@datasource2 "
I guess my quesion would be is there any way to use/access multiple
datasources for creation of a single data set in BIRT.
Thanks in advance.
Arash
Re: MULTIPLE DATA SETS [message #122269 is a reply to message #120605] Tue, 31 January 2006 19:39 Go to previous message
You cannot create a single data set based on two different data sources in
BIRT 2.0.
However you can use nested query in BIRT to achieve some limited cross data
source joins. I had a earlier post that explains how this works. Check out
my post titled "re: Computed field based on other dataset" posted on
1/24/06.
regards,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"ARASH " <ARASH.BARIRANI@VERIZONWIRELESS.COM> wrote in message
news:0673b71ba6d30b16ca4d098e8bf621f2$1@www.eclipse.org...
> "create table a as
> Thanks in advance.
> Arash
Previous Topic:Blank default value for Report Parameter
Next Topic:Internal server error
Current Time: Thu Nov 06 17:54:32 EST 2025
Powered by FUDForum. Page generated in 0.05774 seconds
