Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Compare file against nothing
[EMF Compare] Compare file against nothing [message #120546] Tue, 29 April 2008 10:25 Go to next message
One more question regarding ModelComparator: in case one of the resource
(left or right) is null, it is not able to run the diff. In that case I
would assume the diff is the whole non-null file.
David
Re: [EMF Compare] Compare file against nothing [message #120615 is a reply to message #120546] Tue, 29 April 2008 11:09 Go to previous messageGo to next message
--------------070902080707000201050607
David,
Whether the comparison is made through the UI (thus via ModelComparator)
or through code (via MatchService and DiffService), We do assume that
each of the compared objects are loaded within a resource. Comparison
will fail in NullPointerException otherwise.
I will add this in the services' and engines' javadoc since I believe
this isn't documented anywhere.
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #120678 is a reply to message #120615] Wed, 30 April 2008 07:22 Go to previous messageGo to next message
Hi Laurent,
I might be wrong, but I believe this prevents to do diffs between a new file
in your workspace and a team repository (where the file is not present yet).
The text comparator usually shows the whole file content as the diff in
those cases.
I thought in the empty case, you could just instantiate an empty
ResourceImpl so that it works? I haven't tried it though, so it's just a
suggestion.
David
Stack trace with CVS:
Caused by: java.lang.NullPointerException
org.eclipse.emf.compare.ui.ModelCompareInput.getAncestor(Mod elCompareInput.java:155)
org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeC ontentProvider.getAncestorContent(ModelContentMergeContentPr ovider.java:63)
org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in ternalRefresh(ContentMergeViewer.java:697)
org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in putChanged(ContentMergeViewer.java:615)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.setInput(ModelContentMergeViewer.java:299)
org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:254)
org.eclipse.compare.CompareEditorInput.internalSetContentPan eInput(CompareEditorInput.java:784)
org.eclipse.compare.CompareEditorInput.access$7(CompareEdito rInput.java:782)
org.eclipse.compare.CompareEditorInput$13.run(CompareEditorI nput.java:722)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.compare.CompareEditorInput.feed1(CompareEditorIn put.java:716)
org.eclipse.compare.CompareEditorInput.feedInput(CompareEdit orInput.java:694)
org.eclipse.compare.CompareEditorInput.createContents(Compar eEditorInput.java:524)
org.eclipse.compare.internal.CompareEditor.createCompareCont rol(CompareEditor.java:399)
org.eclipse.compare.internal.CompareEditor.access$2(CompareE ditor.java:369)
at org.eclipse.compare.internal.CompareEditor$3.run(CompareEdit or.java:326)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 23 more
and another just before:
org.eclipse.emf.compare.match.service.MatchService.doResourc eMatch(MatchService.java:197)
org.eclipse.emf.compare.ui.internal.ModelComparator$1.run(Mo delComparator.java:168)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:fv7dn0$ebd$1@build.eclipse.org...
> David,
> Regards
> Laurent Goubet
> Obeo
> David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #120689 is a reply to message #120678] Wed, 30 April 2008 08:59 Go to previous messageGo to next message
--------------070308040306080905070008
David,
Could you raise a bug on the bugzilla for this use case? Seems we need
to handle both cases : comparison of a local file not commited yet as
well as comparison of a locally deleted file with the latest from CVS.
Thanks for the feedback!
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #120708 is a reply to message #120689] Wed, 30 April 2008 09:51 Go to previous message
bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=229622 has been
filed.
David
news:fv9qf3$3bi$1@build.eclipse.org...
> David,
> Laurent Goubet
> Obeo
> David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #617952 is a reply to message #120546] Tue, 29 April 2008 11:09 Go to previous message
David,
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #617957 is a reply to message #120615] Wed, 30 April 2008 07:22 Go to previous message
Hi Laurent,
those cases.
suggestion.
David
... 23 more
> David,
> Regards
> Laurent Goubet
> Obeo
> David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #617958 is a reply to message #120678] Wed, 30 April 2008 08:59 Go to previous message
David,
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare] Compare file against nothing [message #617960 is a reply to message #120689] Wed, 30 April 2008 09:51 Go to previous message
filed.
David
> David,
> Laurent Goubet
> Obeo
> David Michonneau a
Previous Topic:[EMF Compare] Broken Reference triggers a diff
Next Topic:[CDO] Problem with single Ecore, multiple packages
Current Time: Wed Nov 05 00:44:52 EST 2025
Powered by FUDForum. Page generated in 0.11319 seconds
