Home » Eclipse Projects » Eclipse Platform » PDE/ANT: Create Ant Build File error in 2.1.1?
PDE/ANT: Create Ant Build File error in 2.1.1? [message #120501] Tue, 02 September 2003 11:54
When I try to use "Create Ant Build File" on Eclipse 2.1.1, I sometimes get
an error message "Can't find plugin org.eclipse.core.resources_2.1.0". It
does create part of the build.xml file, but not all of it.
It seems to occur only for plugins that extend AbstractUIPlugin, not simply
Plugin.
I've tried on a complete fresh workspace for simple test plugins and it
seems to work ok for either type (or else I'd open a bugzilla).
Has anyone else seen this problem and know of a solution?
Can someone suggest some cache or configuration I could try clearing or
refreshing?
David
Previous Topic:Example SQL Editor from "The Java Developers Guide to Eclipse" does not work
Next Topic:Default Editor
Current Time: Wed Nov 05 02:44:38 EST 2025
Powered by FUDForum. Page generated in 0.03886 seconds
