Home » Modeling » GMF (Graphical Modeling Framework) » Building RCP version of my GMF diagram editor
Building RCP version of my GMF diagram editor [message #120395] Thu, 19 April 2007 02:11 Go to next message
Originally posted by: evaandoli.dodo.com.au
Hi building a RCP version of my GMF diagram editor.
It builds ok,
Starts up ok.
But when you invoke a diagram or create a new one I get:-
Diagram is not present in resource
and also
Unable to create this part due to an internal error. Reason for the failure:
org.eclipse.core.runtime.CoreException: ERROR
ERROR
Any clues for anyone on what to do ?
Stu
Re: Building RCP version of my GMF diagram editor [message #120703 is a reply to message #120395] Thu, 19 April 2007 07:43 Go to previous messageGo to next message
Originally posted by: julias.frb.br
Are you sure that you are including the plugins in the running
configuration?
> It builds ok,
> Starts up ok.
> and also
> ERROR
> Stu
Re: Building RCP version of my GMF diagram editor [message #120709 is a reply to message #120703] Thu, 19 April 2007 07:56 Go to previous messageGo to next message
On the .product editor on the second tab (called configuration) my plugin at
the last 3 enteries.
Is that the right spot ?
its all works ok within Eclipse - testing it as an RCP but does wrong when I
build and test the build.
Stu
"Julia Sartori" <julias@frb.br> wrote in message
news:f07kp7$thg$1@build.eclipse.org...
> configuration?
>> It builds ok,
>> Starts up ok.
>> and also
>> failure: org.eclipse.core.runtime.CoreException: ERROR
>> ERROR
>> Thanks,
>> Stu
Re: Building RCP version of my GMF diagram editor [message #120723 is a reply to message #120709] Thu, 19 April 2007 08:16 Go to previous messageGo to next message
A bit more info - the GMF editor works ok - so it seems to be isolated to
the diagram !!!
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f07let$2kb$1@build.eclipse.org...
> at the last 3 enteries.
> I build and test the build.
> Stu
>> configuration?
>>> It builds ok,
>>> Starts up ok.
>>> and also
>>> ERROR
>>> Thanks,
>>> Stu
<solved> Re: Building RCP version of my GMF diagram editor [message #120913 is a reply to message #120723] Fri, 20 April 2007 03:07 Go to previous message
Ok I worked it out.
Something really useful, even though it doesn't tell you, is there is a full
stack dump in the RCP directories.
This then pointed me towards a dependant separate to the diagram JAR file
that I had not added.
news:f07mip$cqc$1@build.eclipse.org...
>the diagram !!!
>> when I build and test the build.
>> Stu
>>> configuration?
>>>> It builds ok,
>>>> Starts up ok.
>>>> and also
>>>> ERROR
>>>> Thanks,
>>>> Stu
Previous Topic:dynamic tooltips
Next Topic:Send to back for labels of side affixed symbols
Current Time: Thu Nov 06 23:51:59 EST 2025
Powered by FUDForum. Page generated in 0.04063 seconds
