| org.eclipse.cdt.utils- Plugin [message #120342] |
Thu, 09 September 2004 01:35  |
Originally posted by: maranan.coolgoose.com
Hi all,
May I know where "org.eclipse.cdt.utils" plug-in is available? It is
not available with cdt.
When I tried to compile a piece of code, I got the error "package
org.eclipse.cdt.utils.ui.controls does not exist". That is the reason
why I am looking for this particular plugin.
Maranan
| Re: org.eclipse.cdt.utils- Plugin [message #120624 is a reply to message #120456] |
Fri, 10 September 2004 01:04  |
Thanks Dave.
Lemmme try this..
Maranan
Dave Inglis wrote:
> It is not a plugin, the package can be found in the cdt.ui plugin. Its
> under it own source directory "utils.ui", check your java project build
> paths and make sure it did not get removed as a source path. Or you can
> use the PDE Tools -> Update classpath... in the context menu (right
> click) on the cdt.ui plugin project to fix this.
> Dave.
> maranan wrote:
>> Hi all,
>> Thanks,
>> Maranan
FUDForum. Page generated in 0.03499 seconds
