Home » Newcomers » Newcomers » metadata
metadata [message #120304] Mon, 28 November 2005 22:06
Originally posted by: maricar_mara.yahoo.com
I've tried to get one project from CVS but i am getting the following
error:
Could not write metadata for: <project name>
i keep on getting the following error below:
Could not create indexed cursor:
/home/mbm/workspace/.metadata/.plugins/org.eclipse.core.reso urces/.projects/2k4.0.2/.properties.
org.eclipse.core.internal.resources.ResourceException(/home/ mbm/workspace/.metadata/.plugins/org.eclipse.core.resources/ .projects/2k4.0.2/.properties)[271]:
org.eclipse.core.runtime.CoreException[272]: java.lang.NullPointerException
at java.lang.Object.getClass() (/usr/lib/libgcj.so.6.0.0)
at org.eclipse.core.internal.indexing.ObjectStore.commit() (Unknown Source)
at org.eclipse.core.internal.indexing.ObjectStore.close() (Unknown Source)
org.eclipse.core.internal.indexing.IndexedStore.create(java. lang.String)
(Unknown Source)
at org.eclipse.core.internal.indexing.IndexedStore.open(java.la ng.String)
(Unknown Source)
at org.eclipse.core.internal.properties.IndexedStoreWrapper.ope n()
(Unknown Source)
at org.eclipse.core.internal.properties.IndexedStoreWrapper.rec reate()
(Unknown Source)
at org.eclipse.core.internal.properties.IndexedStoreWrapper.cre ate()
(Unknown Source)
at org.eclipse.core.internal.properties.IndexedStoreWrapper.get Store()
(Unknown Source)
at org.eclipse.core.internal.properties.IndexedStoreWrapper.get Index()
(Unknown Source)
at org.eclipse.core.internal.properties.IndexedStoreWrapper.get Cursor()
(Unknown Source)
org.eclipse.core.internal.properties.PropertyStore.recordsMa tching(org.eclipse.core.internal.properties.ResourceName,
org.eclipse.core.runtime.QualifiedName,
org.eclipse.core.internal.properties.IVisitor) (Unknown Source)
org.eclipse.core.internal.properties.PropertyStore.get(org.e clipse.core.internal.properties.ResourceName,
org.eclipse.core.runtime.QualifiedName) (Unknown Source)
org.eclipse.core.internal.properties.PropertyManager.getProp erty(org.eclipse.core.resources.IResource,
org.eclipse.core.internal.resources.Resource.getPersistentPr operty(org.eclipse.core.runtime.QualifiedName)
(Unknown Source)
org.eclipse.team.core.RepositoryProvider.getProvider(org.ecl ipse.core.resources.IProject,
java.lang.String) (Unknown Source)
org.eclipse.team.internal.ccvs.ui.CVSLightweightDecorator.ge tCVSProviderFor(org.eclipse.core.resources.IResource)
(Unknown Source)
org.eclipse.team.internal.ccvs.ui.CVSLightweightDecorator.de corate(java.lang.Object,
org.eclipse.jface.viewers.IDecoration) (Unknown Source)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(java.lang.Object,
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run()
(Unknown Source)
org.eclipse.core.internal.runtime.InternalPlatform.run(org.e clipse.core.runtime.ISafeRunnable)
(Unknown Source)
org.eclipse.core.runtime.Platform.run(org.eclipse.core.runti me.ISafeRunnable)
(Unknown Source)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(java.lang.Object,
org.eclipse.ui.internal.decorators.DecorationBuilder,
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition)
(Unknown Source)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(java.lang.Object,
org.eclipse.ui.internal.decorators.DecorationBuilder, boolean) (Unknown
Source)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (org.eclipse.core.runtime.IProgressMonitor)
(Unknown Source)
Could not open indexed store:
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
(Unknown Source)
at org.eclipse.core.internal.jobs.Worker.run() (Unknown Source)
Previous Topic:Problems running webapp on server
Next Topic:Unable to load class Webdev
Current Time: Fri Nov 21 11:52:29 EST 2025
Powered by FUDForum. Page generated in 0.11195 seconds
