How to configure Eclipse and CVSNT? [message #120250] |
Mon, 28 November 2005 18:28  |
Originally posted by: kirk.woellert.arlingtoninstitute.org
platform: Winserver 2003
CVSNT: CVSNT 2.5.03 (scorpio) build 2151
Repository location: C:/cvsrepo/test
Repository name: /cvsrepo/test
publish repository: checked
online: checked
compatibility
non-cvsnt compatible clients- all boxes checked
cvsnt compatible clients- no boxes checked
Eclipse:
Version: 3.1.1
Build id: M20050929-0840
Team
connection method: "use another connection method type to connect"
connection type: extssh
CVS Entry Profile
repository path: /cvsrepo/test
use default port: checked
Error msg: Error fetching resource list from repository. Reason: Uknown
response received from cvs server:
Comment: using PKA keys generated by Eclipse. As can be seen from the
WinSSHD server log entries, Eclipse can establish an ssh session, but
apparently cannot connect to CVSNT. Also tried SmartCVS using its
generated keys get the same result.
-------------log file entries from WinSSHD server------
Eclipse Client
[021] WinSSHD 4.06a: Session thread 1017 handling connection from
192.168.1.83:2445:
Connection from 192.168.1.83:2445 accepted.
[022] WinSSHD 4.06a: Session thread 1017 handling connection from
192.168.1.83:2445:
Client version string: SSH-2.0-JSCH-0.1.18
[039] WinSSHD 4.06a: Session thread 1017 handling connection from
192.168.1.83:2445:
Logon attempt 1 for user name 'kirk' with logon method 'password' failed:
The system function
LogonUser() failed with the following error: Windows error 1326: Logon
failure: unknown user name or bad password.
[040] WinSSHD 4.06a: Session thread 1017 for Windows account
'ARISTOTLE\KIRK' from 192.168.1.83:2445:
Logon attempt 2 for user name 'kirk' with logon method 'password'
succeeded.
[049] WinSSHD 4.06a: Session thread 1017 for Windows account
Session server 45: Session server created.
[055] WinSSHD 4.06a: Session thread 1017 for Windows account
Session server 45: Executing command 'cmd.exe /c cvs server' in working
directory
'C:\Documents and Settings\KIRK'.
[050] WinSSHD 4.06a: Session thread 1017 for Windows account
Session server 45: Closing session server.
SmartCVS client
[021] WinSSHD 4.06a: Session thread 1016 handling connection from
192.168.1.83:2442:
Connection from 192.168.1.83:2442 accepted.
[022] WinSSHD 4.06a: Session thread 1016 handling connection from
192.168.1.83:2442:
SSH-2.0-http://3sp.com_J2SSH_Maverick_1.2.5__SmartCVS
[040] WinSSHD 4.06a: Session thread 1016 for Windows account
'ARISTOTLE\KIRK' from 192.168.1.83:2442:
Logon attempt 1 for user name 'kirk' with logon method 'publickey'
(algorithm: 'ssh-dss', public key MD5:
6b:e5:f1:3b:5b:96:60:75:43:76:f5:8e:ae:17:39:8a, with signature) succeeded.
[049] WinSSHD 4.06a: Session thread 1016 for Windows account
Session server 44: Session server created.
[055] WinSSHD 4.06a: Session thread 1016 for Windows account
Session server 44: Executing command 'cmd.exe /c cvs server' in working
directory
[050] WinSSHD 4.06a: Session thread 1016 for Windows account
Session server 44: Closing session server.
[093] WinSSHD 4.06a: Session thread 1016 for Windows account
The client disconnected and sent the following disconnect reason:
SSH_DISCONNECT_BY_APPLICATION, description: The user disconnected the
application
Re: How to configure Eclipse and CVSNT? [message #121214 is a reply to message #120250] |
Thu, 01 December 2005 18:22  |
> online: checked
> compatibility
> Eclipse:
> Version: 3.1.1
> Team
> CVS Entry Profile
I use pserver for CVSNT at home, but for work, where I use a Unix box
for the CVS server, I use "ext" connection type, and under the Ext
Connection Method section of preferences, I use:
CVS_RSH: C:\PuTTY\plink.exe
Parameters: -ssh -2 {user}@{host}
CVS_SERVER: cvs
I use the plink program from PuTTY (a free tool for SSH and Telnet) and
I use the pageant.exe on my PC to manage the SSH key. This way, I enter
my pass phrase once into pageant once and then when Eclipse connects
with the server, I don't have to enter any passwords in or anything.
I haven't tried that with CVSNT yet (any may not as it does what I need
for home, namely version controlling files).
Just thought I'd mention it, in case it helps you in your situation. I
bashed my head against the wall a lot, trying to get Eclipse to talk
to the Unix CVS server.
PCM
FUDForum. Page generated in 0.08433 seconds
