Home » Modeling » GMF (Graphical Modeling Framework) » Initializing empty diagrams on a shared model
Initializing empty diagrams on a shared model [message #120232] Wed, 18 April 2007 10:04 Go to next message
I'm using Initialize diagram X on a shared emf model to create multiple
views of the same model. However, even when I have set syncronized
to be false, the newly created diagrams show all the elements that already
exist
in the model. However, I really want to launch a blank diagram
which I can add new elements to.
Is there anyway to make this happen?
Andy
Re: Initializing empty diagrams on a shared model [message #120436 is a reply to message #120232] Thu, 19 April 2007 03:53 Go to previous messageGo to next message
Make sure that ???RootEditPart#createDefaultEditPolicies() doesn't
install a ???CannonicalEditPolicy.
if there is code like:
installEditPolicy(EditPolicyRoles.CANONICAL_ROLE, new
???CanonicalEditPolicy());
the diagram is still syncronized.
setting syncronized to false should normaly remove this code after
regenerating.
ase schrieb:
> Hello,
> exist
> Andy
Re: Initializing empty diagrams on a shared model [message #120511 is a reply to message #120232] Thu, 19 April 2007 05:24 Go to previous messageGo to next message
Hello ase,
Comment out "new DiagramContentsInitializer().initDiagramContents(..)" in
???NewDiagramFileWizard.
Alex Shatalin
Re: Initializing empty diagrams on a shared model [message #120550 is a reply to message #120511] Thu, 19 April 2007 05:38 Go to previous messageGo to next message
Thanks Alex,
This seems a very important thing to be able to control via the gmfgen
parameters
as I would have thought by default most shared view implementations would
not
want to show the existing elements.
Can it be added as a feature request?
Andy
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e612b298c9508c7f6a8abc@news.eclipse.org...
> Hello ase,
> Alex Shatalin
Re: Initializing empty diagrams on a shared model [message #120562 is a reply to message #120436] Thu, 19 April 2007 05:46 Go to previous messageGo to next message
Thanks, but this doesn't solve the problem of the elements that are shared
with other views
of the same domain model - they still get added.
I think Alex's email is right in that you have to remove some code, but it
does feel like my
scenario is a common one to want to control via the gmfgen model.
Andy
"Andreas Schuster" <a.schuster@exxcellent.de> wrote in message
news:f0773g$js0$1@build.eclipse.org...
> Make sure that ???RootEditPart#createDefaultEditPolicies() doesn't install
> regenerating.
> ase schrieb:
>> Hello,
>> already exist
>> Thanks,
>> Andy
Re: Initializing empty diagrams on a shared model [message #120574 is a reply to message #120550] Thu, 19 April 2007 05:49 Go to previous messageGo to next message
Hello ase,
Sure - create a reuest.
Alex Shatalin
Re: Initializing empty diagrams on a shared model [message #120694 is a reply to message #120511] Thu, 19 April 2007 07:36 Go to previous messageGo to next message
Hi Alex,
there's no DiagramContentsInitializer or anything similar in my gmf
project. Is the class/method obsolete? I'm working with GMF 2.0M6
Alex Shatalin schrieb:
> Hello ase,
> in ???NewDiagramFileWizard.
> Alex Shatalin
Re: Initializing empty diagrams on a shared model [message #120716 is a reply to message #120694] Thu, 19 April 2007 08:04 Go to previous messageGo to next message
Try searching for
initDiagramContents
in your .diagram files.
If it's been addressed a more sensible way, then great, but I doubt it.
Andy
news:f07k6b$sg1$1@build.eclipse.org...
> Hi Alex,
>> Hello ase,
>> Alex Shatalin
Re: Initializing empty diagrams on a shared model [message #121176 is a reply to message #120694] Mon, 23 April 2007 07:08 Go to previous messageGo to next message
Hello Andreas,
This class should be generated only for non-synchronized diagrams. Do you
have synchronized diagram?
Alex Shatalin
Re: Initializing empty diagrams on a shared model [message #121557 is a reply to message #121176] Tue, 24 April 2007 10:55 Go to previous message
hi alex,
thats it. i've generated a syncronized diagram.
but good to know. i'm trying to implement different actions, that makes
it possible to initialize filled or empty diagrams. the
DiagramContentsInitializer is exactly what i need for this approach.
> Hello Andreas,
> you have synchronized diagram?
> Alex Shatalin
Previous Topic:Propsheet : How to integrate the plugin propsheet in my model
Next Topic:EOpposite problem
Current Time: Tue Jul 22 22:11:48 EDT 2025
Powered by FUDForum. Page generated in 0.06836 seconds
