Home » Modeling » GMF (Graphical Modeling Framework) » Does EMF/GMF support this?
Does EMF/GMF support this? [message #120218] Wed, 18 April 2007 10:02 Go to next message
I'm a newbie with GMF and I can't figure out how to correctly define a
link mapping from my schema. At present I have specific requirements as
to how the resulting XML looks - something like this:
<Links about="whatever...">
<columnComparison columnOperator="EQ" sourceCol="x" targetCol="y"/>
<cardinality>1:M</cardinality>
<source resource="http://tempuri.org"/>
<target resource="http://tempuri.org"/>
</Links>
Following is part of my schema - note how the source/target features
needed for the link mapping are defined as XML attributes.
<xsd:element name="Relations">
<xsd:complexType>
<sequence>
<element name="Tables" type="TableType" />
<element name="DerivedTables" type="DerivedTableType" />
<element name="QueryDerivedTables" type="QueryDerivedTableType" />
<element name="Links" type="dam:LinkType" minOccurs="0"
maxOccurs="unbounded" />
</sequence>
</xsd:complexType>
</xsd:element>
<xsd:complexType name="LinkType" ecore:name="Link">
<xsd:sequence>
<element name="columnComparison" type="dam:ColumnComparisonType"
minOccurs="1" maxOccurs="unbounded" />
<element name="cardinality" type="dam:CardinalityEnum" minOccurs="1"/>
<element name="source" type="dam:resourceAttributeType"
minOccurs="1"/>
<element name="target" type="dam:resourceAttributeType"
minOccurs="1"/>
</xsd:sequence>
<xsd:attribute name="about" type="xsd:string" />
</xsd:complexType>
<xsd:complexType name="resourceAttributeType"
ecore:name="ResourceAttribute">
<xsd:attribute name="resource" type="xsd:anyURI"
ecore:reference="dam:AbstractTableBase" />
</xsd:complexType>
Thanks in advance for any help.
Re: Does EMF/GMF support this? [message #120295 is a reply to message #120218] Wed, 18 April 2007 11:16 Go to previous messageGo to next message
I should have added... Once I select 'links' as the EReference for the
domain element/containment feature; then that only allows me to select
"Link" as the containment feature/Element; and therefore the 'resource'
EAttribute is not a valid choice. So I'm starting to think this schema
is the problem (i.e. these constructs aren't supported?).
> </Links>
> <xsd:complexType>
> <sequence>
> </sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> type="dam:ColumnComparisonType" minOccurs="1"
> minOccurs="1"/>
> minOccurs="1"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:complexType>
Re: Does EMF/GMF support this? [message #120357 is a reply to message #120218] Wed, 18 April 2007 14:15 Go to previous message
Mark,
I'm not sure I really understand the GMF part of the question, but for
the anyURI value of the "resource" attribute to be handled as an
EReference in EMF, the URI will have to be of the form
<baseURI>#<fragment> where the baseURI determines the resource, and the
fragment determines the referenced object within the resource.
> as to how the resulting XML looks - something like this:
> </Links>
> <xsd:complexType>
> <sequence>
> minOccurs="0" maxOccurs="unbounded" />
> </sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> minOccurs="1"/>
> minOccurs="1"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:complexType>
Previous Topic:How to add manually some model "elements" to a diagram (where "elements" are giv
Next Topic:How to not to persist the notational views
Current Time: Sun Nov 09 15:24:05 EST 2025
Powered by FUDForum. Page generated in 0.03652 seconds
