Home » Eclipse Projects » GEF » Upgrade from eclipse5.0 to eclipse5.1
Upgrade from eclipse5.0 to eclipse5.1 [message #120212] Wed, 03 March 2004 01:45 Go to next message
Originally posted by: lizhih.cn.ibm.com
I have developed a plugin using the EMF 1.01 on WSADIE5.0 , when I try to
run it on WSADIE5.1 , it doesn't work .
I've check the plugins in WSADIE5.1 , under the plugin folder
:org.eclipse.ui.2.1.1,no workbench.jar exists , but we used a lot of this
jar file on WSADIE5.0 , how to solve this problem?
Have anybody met this problem before ? Thank you in advance!
Re: Upgrade from eclipse5.0 to eclipse5.1 [message #120373 is a reply to message #120212] Wed, 03 March 2004 10:11 Go to previous message
Try asking on the EMF newsgroup.
"hellen" <lizhih@cn.ibm.com> wrote in message
news:c23um4$mb3$1@eclipse.org...
Previous Topic:Need HELP! Performance problem
Next Topic:The class KeyBindingService in Eclipse2.1 was changed from Public to final,but if I want to use , wh
Current Time: Fri Nov 21 00:45:37 EST 2025
Powered by FUDForum. Page generated in 0.27268 seconds
