Home » Newcomers » Newcomers » Debug Code Changes
Debug Code Changes [message #120133] Mon, 28 November 2005 10:37 Go to next message
I'm a bit confused because this is a new issue that I have not experienced
before. I am running Eclipse 3.1.1. In the past when I ran an Eclipse
project, I could make code change while in debug perespective, save my
changes and see the expected results while debugging w/o having to stop
the debugger, or build or anything else. All of a sudden this
functionality is no longer working for me. I now need to stop the debuger
and then perform a clean build on the project that I made the change in
order for my new code to be picked up. This includes both debugging and
just running the project. Can someone please help me with this? Has
something changed in my perferences that I'm not aware of.
Thanks in advance for your help and support,
Ben
Re: Debug Code Changes [message #120160 is a reply to message #120133] Mon, 28 November 2005 11:41 Go to previous messageGo to next message
Have you turned off auto-build? This triggers a build on your save of
changes and results in an update of the class files on the running VM.
Project>Build Automatically
HTH
Darins
"Ben Sisson" <bsisson@simventions.com> wrote in message
news:7f233f8ddb76698537431b8cbf23124a$1@www.eclipse.org...
> Ben
Re: Debug Code Changes [message #120458 is a reply to message #120160] Tue, 29 November 2005 08:46 Go to previous message
That solved the problem.
Ben
Previous Topic:Runtime
Next Topic:PHP Browser
Current Time: Wed Nov 05 00:30:29 EST 2025
Powered by FUDForum. Page generated in 0.09016 seconds
