Home » Archived » Test and Performance Tools Platform (TPTP) » How to profile JBoss server by TPTP on LINUX(SUSE 9.3) Environment
| How to profile JBoss server by TPTP on LINUX(SUSE 9.3) Environment [message #120003] |
Wed, 02 January 2008 12:53  |
Originally posted by: takashi.s.interplay.blogdns.com
Hello There
Currently, I'm trying to use TPTP on this environment.
I want to monitor remote JBoss application server
OS: SUSE 9.3
Eclipse: 3.2
Java: 1.5.0_10
Target Server: jboss-4.2.2.GA
TPTP (Installed from Eclipse)
TPTP Agent controller 4.4.0.3
I added this statement to startup script of JBOSS "run.sh".
JAVA_OPTS="-agentlib:JPIBootLoader=JPIAgent:server=enabled $JAVA_OPTS"
When I execute "run.sh" it will always return this error,
"Error occurred during initialization of VM agent library failed to init:
JPIBootLoader".
I googled about this, but couldn't find useful information.
Is anyone who faced this problem and fixed, pls let me know.
My /etc/skel/.profile is
TPTP_AC_HOME=/usr/local/agent
JAVA_PROFILER_HOME=$TPTP_AC_HOME/plugins/org.eclipse.tptp.ja vaprofiler
LD_LIBRARY_PATH=$JAVA_PROFILER_HOME:$TPTP_AC_HOME/lib
export TPTP_AC_HOME
export JAVA_PROFILER_HOME
export LD_LIBRARY_PATH
PATH=$TPTP_AC_HOME/bin:$JAVA_PROFILER_HOME:$PATH
I think every environmental valuables are set collectly.
However, maybe something is wrong with my configuration.
Any suggestion about this is quite appriciated.
Best regards.
Takashi
| Re: How to profile JBoss server by TPTP on LINUX(SUSE 9.3) Environment [message #120068 is a reply to message #120031] |
Thu, 03 January 2008 08:15   |
Asaf,
Thank you for your reply.
As you said in previous mail, I fixed the "run.sh" as you specified. Then I
don't get original error
However, other 2 problem happens.
1. Got exception when I restart agent controller
When I try to restart agent controller on SUSE server, I got this message,
Starting Agent Controller.
Exception in thread "Thread-0" java.lang.NoClassDefFoundError:
org/eclipse/hyades/internal/execution/file/FileServer
ACServer started successfully.
It seems the agent controller starts successfully after getting Exception in
thread.
But if it's possible, I want to fix this problem.
2. Can't attach to agent controller from Eclipse
When I tried to attach to remote controller agent from eclipse,I got this
error message.
"IWAT0435E An error occured when connecting to host"
This is because of the version of Eclipse???
I tried to access to the remote agent running in SUSE server as I described
in previous mail.
My client environment is,
OS: Windows XP Pro
Eclipse: 3.2
Jdk: 1.5.0_14
Also, I got this error message from JBoss server that I tried to profile,
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00002af89c0111f9, pid=1978, tid=1106332000
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_10-b03 mixed mode)
# Problematic frame:
# C [libtptpCmdExtr.so+0x21f9] parseMessage+0xe9
# An error report file with more information is saved as hs_err_pid1978.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
I can't understand what affects my JBoss server.
Any suggestion for those trouble is really appriciated.
Best regards
Takashi
"Asaf Yaffe" <asaf.yaffe@intel.com> wrote in message
news:fliaov$qpn$1@build.eclipse.org...
> Takashi,
>> OS: SUSE 9.3
>> Eclipse: 3.2
>> Java: 1.5.0_10
> TPTP 4.4 is designed to run with Eclipse 3.3. I suggest you to upgrade if
> you can.
> The -agentlib option is missing the data collector to launch (CGProf,
> HeapProf or ThreadProf). Consider modifying this line to
> JAVA_OPTS="-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf
> $JAVA_OPTS"
> Please see the online documentation (under Profiling in Standalone mode)
> for a complete list of available options.
> If this does not solve the problem, please enable logging by defining the
> following variables:
> export MARTINI_LOGGER_DIRECTORY=<an existing directory of your choice>
> export MARTINI_LOGGER_LOG_LEVEL=5
> Then, reproduce the error and post the created MLog*.log file to this
> newsgroup.
> HTH,
> Asaf
> Asaf Yaffe
> Eclipse TPTP Committer, JVMTI Profiler
| Re: How to profile JBoss server by TPTP on LINUX(SUSE 9.3) Environment [message #120154 is a reply to message #120068] |
Thu, 03 January 2008 10:50   |
Sorry I have to collect one thing in my previous mail. I said,
> hs_err_pid5991.log
This is not the error of JBoss, When I tried to attach to the remote JBoss
server,
The agent controller running in remote server gave this error and stopped
suddenly....
Pls tell me what is the possible cause.
I also tried from Eclipse3.3, however, result was same.....
I attached the logfile "hs_err_pid5991.log" just in case.
I'm completly stacked....
"Takashi" <takashi.s@interplay.blogdns.com> wrote in message
news:flin5s$vqj$1@build.eclipse.org...
> Asaf,
> I
> in
> thread.
> error message.
> described
> in previous mail.
> OS: Windows XP Pro
> Eclipse: 3.2
> Jdk: 1.5.0_14
> hs_err_pid1978.log
> Best regards
> Takashi
>> Takashi,
>>> OS: SUSE 9.3
>>> Eclipse: 3.2
>>> Java: 1.5.0_10
>> you can.
>> $JAVA_OPTS"
>> newsgroup.
>> HTH,
>> Asaf
>> Asaf Yaffe
| Re: How to profile JBoss server by TPTP on LINUX(SUSE 9.3) Environment [message #120955 is a reply to message #120154] |
Wed, 16 January 2008 08:00  |
Takashi,
This seems like an Agent Controller issue. Maybe some of the AC guys can
help....
Asaf
>> hs_err_pid5991.log
> server,
> suddenly....
>> Asaf,
>> I
>> in
>> thread.
>> error message.
>> described
>> in previous mail.
>> OS: Windows XP Pro
>> Eclipse: 3.2
>> Jdk: 1.5.0_14
>> hs_err_pid1978.log
>> Best regards
>> Takashi
>>> Takashi,
>>>> OS: SUSE 9.3
>>>> Eclipse: 3.2
>>>> Java: 1.5.0_10
>>> you can.
>>> $JAVA_OPTS"
>>> newsgroup.
>>> HTH,
>>> Asaf
>>> Asaf Yaffe
Current Time: Thu Nov 06 02:28:02 EST 2025
Powered by FUDForum. Page generated in 0.04637 seconds
