Home » Archived » BIRT » error setting image visibility
error setting image visibility [message #119994] Mon, 30 January 2006 11:21
Originally posted by: stefano.comarin.primeur.com
I have a report with an image whose visibility is set at runtime based
on a parameter. When I create a PDF report with the BIRT 2.0 engine on
the command line and the image visibility is false I get this error:
Jan 30, 2006 5:06:28 PM
org.eclipse.birt.report.engine.layout.impl.ImageLayoutManage r layout
SEVERE: can't retrieve image intrinsic dimension!
The report is generated but instead of the image I get an empty space,
instead there should be no space at all! Any ideas?
Stefano
Previous Topic:Birt Viewer (Tomcat 4.1) Displays No Records
Next Topic:Using Birt in an RCP application
Current Time: Mon Nov 17 11:37:20 EST 2025
Powered by FUDForum. Page generated in 0.03013 seconds
