Home » Language IDEs » Java Development Tools (JDT) » M5 SuSE 8.2/Gtk Java Preferences Issues
M5 SuSE 8.2/Gtk Java Preferences Issues [message #119971] Mon, 24 November 2003 08:12 Go to next message
After loading M5 into a new directory, I followed my typical procedure of
setting up preferences and looking around to see what else is new in the
build.
On a clean build, when I choose either the "Installed JRE's" or "Javadoc"
preferences, Eclipse hangs. I end up killing the application.
If I take a copy of my M4 data/workspace directory and set M5 to use the
copy, it does get better. I can bring up both preferences dialogs. If,
however, I try to add a JRE, the application hangs once again. I go
through all the steps to create the JRE, then when I press OK to accept
the new JRE, Eclipse hangs.
Is this a known issue? I took a quick scan of bugzilla and didn't find
anything resembling this issue. Shall I enter a bug on this behavior?
Ray Elenteny
Re: M5 SuSE 8.2/Gtk Java Preferences Issues [message #127387 is a reply to message #119971] Mon, 15 December 2003 06:10 Go to previous message
>build.
Yes.
Dani
>Thanks,
>Ray Elenteny
Previous Topic:Using org.eclipse.jdt.ui.examples.javafamily
Next Topic:How to switch to the Debug perspective
Current Time: Sat Jul 26 09:31:00 EDT 2025
Powered by FUDForum. Page generated in 0.03726 seconds
