Trying to get the pooled db connection working [message #119807] |
Mon, 30 January 2006 09:42  |
Originally posted by: jarif.despammed.com
This IS really hard? Is it supposed to still work with 2.0 final?
I created the two plugins, the driver plugin with classes for Driver and
Plugin (extending BIRTPlugin)
The DataSource seem to fetch objects from database in designer, but when
trying to define a Data Set an error is shown:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.0.0
Error Code:odaconsumer.OdaInitEntryNotFound
Error Message:The driver com.k2datasolutions.birt.report.data.oda.jdbcs
initial entry point cannot be found or cannot be instantiated.
Unable to create the ODA driver's connection factory.
com.k2datasolutions.birt.report.data.oda.jdbc is the package name where the
driver and plugin classes are, as well as the id plugin.xml
<plugin
id="com.k2datasolutions.birt.report.data.oda.jdbc"
name="K2 BIRT ODA-JDBC Bridge Driver"
version="1.0.0"
provider-name="k2datasolutions.com"
class=" com.k2datasolutions.birt.report.data.oda.jdbc.SubOdaJdbcPlug in ">
<runtime>
<library name="K2OdaJdbcDriver.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.birt.report.data.oda.jdbc"/>
</requires>
<extension-point id="driverinfo" name="JDBC Driver Information
Extension"
schema="schema/driverinfo.exsd"/>
<extension
point="org.eclipse.datatools.connectivity.oda.dataSource">
<dataSource
odaVersion="3.0"
driverClass=" com.k2datasolutions.birt.report.data.oda.jdbc.SubOdaJdbcDriv er
defaultDisplayName="JNDI Data Source"
setThreadContextClassLoader="false">
... the rest is intact.
What might be the reason? This is really puzzling.
Re: Trying to get the pooled db connection working [message #120073 is a reply to message #119807] |
Mon, 30 January 2006 11:49   |
------=_NextPart_000_0476_01C6257A.15D905E0
Content-Type: text/plain;
charset="iso-8859-1"
Jari,
I can't figure out what could be wrong without seeing your source code. =
But looking at your plugin.xml I guess you are trying to write a plugin =
to provide pooled JDBC connections to BIRT. Such a task can generated by =
achieve by writing a plugin to extend the =
org.eclipse.birt.report.data.oda.jdbc.driverinfo extension point. Here =
is the step-by-step instruction for how to do that:=20
(1) Create an eclipse plugin and seti it to depend on the BIRT plugin =
(2) In your plugin create a extension for the =
org.eclipse.birt.report.data.oda.jdbc.driverinfo extension point. Add a =
jdbcDriver element in the Eclipse extension editor. Give your driver a =
name, an URL template (that should usually look like =
"jdbc:your_company_name:your_data_source_name"), and also a =
connectionFactory. The connection factory is a class that implements =
interface org.eclipse.birt.report.data.oda.jdbc.IConnectionFactory.=20
(3) Write your connection factory implementation so that it gives out =
pooled jdbc Connections.
Once this is done, you can use BIRT designer to create a regular JDBC =
Data Source. You should then be able to see your own driver name in the =
list of available JDBC data sources.=20
As an example, look at how the BIRT =
org.eclipse.birt.report.data.oda.sampledb plugin implements the =
driverinfo extension.=20
--=20
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Jari Fredriksson" <jarif@despammed.com> wrote in message =
news:Xns975BA9F92A00DSH15SGybs1ysmajw54s5@206.191.52.34...
>=20
>=20
>=20
> I created the two plugins, the driver plugin with classes for Driver =
and=20
>=20
> The DataSource seem to fetch objects from database in designer, but =
when=20
> Version:2.0.0
> Error Message:The driver =
com.k2datasolutions.birt.report.data.oda.jdbcs=20
>=20
> com.k2datasolutions.birt.report.data.oda.jdbc is the package name =
where the=20
>=20
> <plugin
> id=3D"com.k2datasolutions.birt.report.data.oda.jdbc"
> name=3D"K2 BIRT ODA-JDBC Bridge Driver"
> version=3D"1.0.0"
> provider-name=3D"k2datasolutions.com"
class=3D" com.k2datasolutions.birt.report.data.oda.jdbc.SubOdaJdbcPlug in ">=
> <runtime>
> <library name=3D"K2OdaJdbcDriver.jar">
> <export name=3D"*"/>
> </library>
> </runtime>
> <requires>
> <import plugin=3D"org.eclipse.birt.report.data.oda.jdbc"/>
> </requires>
> =20
> <extension-point id=3D"driverinfo" name=3D"JDBC Driver Information=20
> Extension"=20
> schema=3D"schema/driverinfo.exsd"/>
> =20
> <extension
> point=3D"org.eclipse.datatools.connectivity.oda.dataSource" >
> <dataSource
> odaVersion=3D"3.0"
> =20
driverClass=3D"com.k2datasolutions.birt.report.data.oda.jdbc.SubOdaJdbcDr=
iver
> defaultDisplayName=3D"JNDI Data Source"
> setThreadContextClassLoader=3D"false">
>=20
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1528" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Jari,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I can't figure out what could be wrong =
without=20
seeing your source code. But looking at your plugin.xml I guess you are =
trying=20
to write a plugin to provide pooled JDBC connections to BIRT. Such =
a task=20
can generated by achieve by writing a plugin to extend the=20
<EM>org.eclipse.birt.report.data.oda.jdbc.driverinfo</EM> extension =
point.=20
</FONT><FONT face=3DArial size=3D2>Here is the step-by-step instruction =
for how to=20
do that: </DIV>
<DIV>(1) Create an eclipse plugin and seti it to depend on the BIRT =
plugin=20
org.eclipse.birt.report.data.oda.jdbc</DIV>
<DIV>(2) In your plugin create a extension for the=20
point. Add a=20
name, an=20
URL template (that should usually look like=20
connectionFactory.=20
The connection factory is a class that implements interface <FONT=20
size=3D2>org.eclipse.birt.report.data.oda.jdbc.IConnectionFactory. =
</FONT></DIV>
<DIV>(3) Write your connection factory implementation so that it gives =
out=20
pooled jdbc Connections.</DIV>
<DIV> </DIV>
<DIV>Once this is done, you can use BIRT designer to create a regular =
JDBC Data=20
Source. You should then be able to see your own driver name in the list =
of=20
available JDBC data sources. </DIV>
<DIV> </DIV>
<DIV>As an example, look at how the BIRT=20
driverinfo=20
extension. </DIV>
<DIV><BR>-- <BR>Gary Xue<BR>Actuate Corporation - Product =
Development<BR>BIRT=20
Committer</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>"Jari Fredriksson" <</FONT><A=20
href=3D"mailto:jarif@despammed.com"><FONT face=3DArial=20
size=3D2>jarif@despammed.com</FONT></A><FONT face=3DArial size=3D2>> =
wrote in=20
message </FONT><A=20
href=3D"news:Xns975BA9F92A00DSH15SGybs1ysmajw54s5@206.191.52.34"><FONT =
face=3DArial=20
size=3D2>news:Xns975BA9F92A00DSH15SGybs1ysmajw54s5@206.191.52.34</FONT></=
A><FONT=20
face=3DArial size=3D2>...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>> <BR>> </FONT></DIV>
<DIV><BR><FONT face=3DArial size=3D2>> This IS really hard? Is it =
supposed to=20
still work with 2.0 final?<BR>> <BR>> I created the two plugins, =
the=20
driver plugin with classes for Driver and <BR>> Plugin (extending=20
BIRTPlugin)<BR>> <BR>> The DataSource seem to fetch objects from =
database=20
in designer, but when <BR>> trying to define a Data Set an error is=20
shown:<BR>> ------------------------------------<BR>> A BIRT =
exception=20
occurred.<BR>> Plug-in Provider:Eclipse.org<BR>> =
Plug-in=20
Name:BIRT Data Engine<BR>> Plug-in =
Version:2.0.0<BR>> Error=20
Code:odaconsumer.OdaInitEntryNotFound<BR>> Error Message:The =
driver=20
com.k2datasolutions.birt.report.data.oda.jdbcs <BR>> initial entry =
point=20
cannot be found or cannot be instantiated.<BR>> Unable to create the =
ODA=20
driver's connection factory.<BR>>=20
-------------------------------------<BR>> <BR>>=20
com.k2datasolutions.birt.report.data.oda.jdbc is the package name where =
the=20
<BR>> driver and plugin classes are, as well as the id =
plugin.xml<BR>>=20
<BR>> <plugin<BR>> =20
id=3D"com.k2datasolutions.birt.report.data.oda.jdbc"<BR>> =
name=3D"K2=20
BIRT ODA-JDBC Bridge Driver"<BR>> =
version=3D"1.0.0"<BR>>=20
provider-name=3D"k2datasolutions.com"<BR>> =20
class=3D" com.k2datasolutions.birt.report.data.oda.jdbc.SubOdaJdbcPlug in "&=
gt;<BR>>=20
<runtime><BR>> =
<library=20
name=3D"K2OdaJdbcDriver.jar"><BR>>=20
<export=20
name=3D"*"/><BR>> =
</library><BR>>=20
</runtime><BR>> =
<requires><BR>>=20
<import=20
plugin=3D"org.eclipse.birt.report.data.oda.jdbc"/><BR >> =
=20
</requires><BR>> <BR>> =
<extension-point=20
id=3D"driverinfo" name=3D"JDBC Driver Information <BR>> Extension" =
<BR>>=20
schema=3D"schema/driverinfo.exsd"/><BR>> =
<BR>>=20
<extension<BR>>=20
=20
point=3D"org.eclipse.datatools.connectivity.oda.dataSource"> <BR>>=20
<dataSource<BR>>=20
=20
id=3D"com.k2datasolutions.birt.report.data.oda.jdbc"<BR>>=20
=20
odaVersion=3D"3.0"<BR>>=20
<BR>>=20
iver<BR>>=20
"<BR>> =
=20
defaultDisplayName=3D"JNDI Data Source"<BR>>=20
=20
setThreadContextClassLoader=3D"false"><BR>> <BR>> .. the rest =
is=20
intact.<BR>> <BR>> What might be the reason? This is really=20
puzzling.</FONT></DIV></BODY></HTML>
------=_NextPart_000_0476_01C6257A.15D905E0--
Re: Trying to get the pooled db connection working [message #121714 is a reply to message #120352] |
Tue, 31 January 2006 11:02  |
"Jason Weathersby" <jweathersby@actuate.com> wrote in
news:drluo0$kd1$1@utils.eclipse.org:
> Jari
> Gary's way is probably better, but I uploaded an example of this under
> the rptdesign file changes for connection pool thread.
> Jason
It might be better, but your example works like charm. The code is pretty
much same as mine was, but something was wrong... I replaced mine with your
example, works as needed.
jarif
FUDForum. Page generated in 0.42271 seconds
