Home » Eclipse Projects » Remote Application Platform (RAP) » Internationalization of "Core Plugins"
Internationalization of "Core Plugins" [message #119793] Tue, 27 January 2009 12:22 Go to next message
I have a question. We are developing a new Product with RAP. Usually when
developing eclipse RCP we split our plugins in "core" and "ui" plugins. The
"core" plugins usually have no references to any "ui" plugins. Now using
this concept for RAP seems to fail with internationalization as the class
"RWT" that is responsible for translation resides in a "ui" plugin.
Does anyone face the same problem and/or has a solution for this?
Markus
Re: Internationalization of "Core Plugins" [message #119882 is a reply to message #119793] Tue, 27 January 2009 15:54 Go to previous messageGo to next message
Originally posted by: adv.zahn.googlemail.com
The problem is that - in RAP - the decision for the user's language can
be made for incoming requests. So I think you have to decide
- system output, e.g. when starting the application (locale is the
JVM's system locale)
- UI output, for that you can use the RWT.NLS class
The result is, that - for system output - you cannot use RWT.NLS if you
want to split in core and ui. Instead, you can use ResourceBundles or
the "good old" org.eclipse.osgi.util.NLS class?
Ralf
Markus Krüger schrieb:
> Markus
Re: Internationalization of "Core Plugins" [message #120027 is a reply to message #119793] Thu, 29 January 2009 06:00 Go to previous messageGo to next message
Markus,
in my opinion, core code should not deal with locale specific
information regarless of the implications that RAP brings into the
topic. Code that needs access to locale information should stay in
the UI thus the problem wouldn't arise in the first place.
If your code plug-in actually needs locale information, you would
need to pass it there from your UI code.
Rüdiger
Markus Krüger wrote:
> Markus
Re: Internationalization of "Core Plugins" [message #120159 is a reply to message #120027] Fri, 30 January 2009 07:57 Go to previous message
Ok, thank you for the information.
"R
Previous Topic:Plugin in for UI design.
Next Topic:Changing default Font / Theming
Current Time: Fri Nov 07 00:39:26 EST 2025
Powered by FUDForum. Page generated in 0.03352 seconds
