| Can't test my plug-in : MappingService unavailable [message #119749] |
Wed, 19 December 2007 07:32  |
Originally posted by: alexandre.vanbelle.3ds.com
I want to automate the test of my plug-in. So, I try to use the features
of TPTP to do it. But I have troubles : it seems that my test workbench
doesn't work properly.
I have make a deployment with an artifact, and an workbench location. I
think my settings are correct. But, when I launch the test, I have some
errors in the .log of the workspace :
!ENTRY org.eclipse.ui 4 4 2007-12-19 13:03:49.684
!MESSAGE MappingService unavailable
or
!SUBENTRY 1 org.eclipse.equinox.registry 2 1 2007-12-19 13:03:42.870
!MESSAGE Unknown element "runtime", found within a "plugin", ignored
(line: 31).
!MESSAGE Unknown element "library", found at the top level, ignored.
!MESSAGE Unknown element "export", found at the top level, ignored.
It is really strange, because, when I launch a new workbench (manually)
with my plug-ins, I have no error at all. It is only with the TPTP test.
Can someone give me an advice to solve my problems ?
Alexandre
| Re: Can't test my plug-in : MappingService unavailable [message #119805 is a reply to message #119749] |
Thu, 20 December 2007 06:47  |
What version of TPTP are you using? Also, are you using ASF or the TPTP
workbench to launch your tests?
Paul
"Alexandre" <alexandre.vanbelle@3ds.com> wrote in message
news:5d1c2fef2c8fbfdc581819ea3ffafb31$1@www.eclipse.org...
> Hello,
> or
> (line: 31).
> Alexandre
FUDForum. Page generated in 0.03502 seconds
