Home » Eclipse Projects » Eclipse Platform » using eclipse as a framework for a custom application
using eclipse as a framework for a custom application [message #119702] Sat, 30 August 2003 05:43 Go to next message
Originally posted by: eugster.informatik.bluewin.ch
Hello there
can anyone help me? I would like to integrate my swing-application as a
plugin and change the environment, that initially it is my application that
is launched by the platform, not the workbench. I am new to eclipse, I did
not find enough explanation in the help an in articles on www.eclipse.org.
What have i to do step by step?
thank you a lot!
chrigel
Re: using eclipse as a framework for a custom application [message #119816 is a reply to message #119702] Sun, 31 August 2003 07:24 Go to previous message
Originally posted by: jmordax.terra.es
Interesting article about the integration of Swing tools in Eclipse.
URL:
http://www-106.ibm.com/developerworks/opensource/library/os- swing/?loc=dwmain
Summary: Learn how to integrate a stand-alone Swing-based editor into
the Eclipse Platform as a plug-in. Using simple techniques, you can
share resources between the Swing tool, the Eclipse Platform, and
various SWT widgets -- and these resources can communicate through
mutual awareness. Tool vendors who want to bring Eclipse-based
development tools to market with a minimal amount of re-coding will also
find this article helpful.
Chemi.
Christian Eugster wrote:
>Hello there
>thank you a lot!
>chrigel
Previous Topic:How to enable a previously disabled pluing?
Next Topic:How to customize the Java Editor behavior after "if (expr)<RETURN>"
Current Time: Thu Jul 17 19:36:51 EDT 2025
Powered by FUDForum. Page generated in 0.07019 seconds
