EXTENSION_POINT_NOT_FOUND [message #119691] |
Mon, 30 January 2006 05:35  |
I am getting following error while running the Java class.
Can any one know why this is coming?
Jan 30, 2006 4:03:51 PM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 484 Milliseconds.
Jan 30, 2006 4:03:52 PM
org.eclipse.birt.report.model.metadata.ExtensionLoader load
SEVERE: Message:The extension point
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
Exception in thread "main" java.lang.IllegalArgumentException: The
extension with ID 'org.eclipse.birt.report.data.oda.jdbc' is not found!
org.eclipse.birt.report.model.extension.oda.ODAManifestUtil. getDataSourceExtension(ODAManifestUtil.java:51)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eODADataSourceExtensionID(OdaDataSourceState.java:105)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eAttrs(OdaDataSourceState.java:55)
org.eclipse.birt.report.model.parser.ModuleParserHandler.sta rtElement(ModuleParserHandler.java:159)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.DTDConfiguration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:89)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:171)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:135)
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:177)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:133)
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:93)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:103)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:219)
at com.Solectron.ParameterPassing.getReport(ParameterPassing.ja va:31)
at com.Solectron.ParameterPassing.main(ParameterPassing.java:13 4)
Re: EXTENSION_POINT_NOT_FOUND [message #120744 is a reply to message #119958] |
Tue, 31 January 2006 04:51   |
Ya i downloaded and set the engine home but still i am getting the
following error.And it is not getting the JDBC connection driver but i
copied the JDBC plugins also.
Jan 31, 2006 3:22:20 PM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 1110 Milliseconds.
Jan 31, 2006 3:22:22 PM
[org.eclipse.birt.report.model.encryptionHelper] is not found. Error
Jan 31, 2006 3:22:23 PM org.eclipse.birt.data.engine.impl.DataEngineImpl
<init>
INFO: Data Engine starts up
Jan 31, 2006 3:22:24 PM org.eclipse.birt.data.engine.odaconsumer.Driver
setLogConfiguration
INFO: ODA driver does not have valid trace logging defined in the plug-in
options or plugin.xml file.
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager
loadDriverExtensions
INFO: Found JDBC driverinfo extension:
driverClass=sun.jdbc.odbc.JdbcOdbcDriver, connectionFactory=null
driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
driverClass=org.eclipse.birt.report.data.oda.sampledb.Driver ,
connectionFactory=org.eclipse.birt.report.data.oda.sampledb. SampleDBJDBCConnectionFactory
loadAndRegisterDriver
INFO: Loading JDBC driver class: sun.jdbc.odbc.JdbcOdbcDriver
INFO: Loaded JDBC driver class in class path: sun.jdbc.odbc.JdbcOdbcDriver
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
SEVERE: Cannot open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Failed to get
connection.
No suitable driver
org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:155)
org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:111)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:239)
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:124)
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:154)
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:147)
org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:150)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.ope nDataSource(PreparedQuery.java:838)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.pre pareExecution(PreparedQuery.java:661)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.acc ess$000(PreparedQuery.java:498)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:225)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:145)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:205)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.op enResultSet(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:122)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:187)
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:69)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
at com.Solectron.Parameter.getReport(Parameter.java:128)
at com.Solectron.Parameter.main(Parameter.java:148)
Caused by: java.sql.SQLException: No suitable driver
at java.sql.DriverManager.getConnection(DriverManager.java:558)
at java.sql.DriverManager.getConnection(DriverManager.java:157)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:148)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:94)
org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:150)
... 21 more
org.eclipse.birt.report.engine.data.dte.DteDataEngine execute
SEVERE: Cannot open the connection for the driver:
Failed to get connection.
No suitable driver
org.eclipse.birt.data.engine.core.DataException: Cannot open the
connection for the driver: org.eclipse.birt.report.data.oda.jdbc
No suitable driver
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:136)
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Failed to
get connection.
No suitable driver
... 18 more
... 21 more
Created Report
Re: EXTENSION_POINT_NOT_FOUND [message #121664 is a reply to message #120744] |
Tue, 31 January 2006 07:49   |
Jack
This is a know issue and it is harmless.
You will notice that this is a different extension point than the one you
reported earlier.
As far as the connection problem
Which JDBC driver are you using?
Did you copy it to the Report
Engine/plugins/org.eclipse.birt.report.data.oda.jdbc/drivers folder?
Jason
"Jack" <jagbhise@in.ibm.com> wrote in message
news:dc5b1d314d0187d5bf964df9ba71dbdc$1@www.eclipse.org...
> code:EXTENSION_POINT_NOT_FOUND Jan 31, 2006 3:22:23 PM
> org.eclipse.birt.data.engine.impl.DataEngineImpl <init>
> setLogConfiguration
> connection.
> No suitable driver
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 21 more
> No suitable driver
> No suitable driver
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> get connection.
> No suitable driver
> at
> at
> at
> at
> ... 18 more
> at
> at
> at
> ... 21 more
> Created Report
FUDForum. Page generated in 0.12445 seconds
