Home » Eclipse Projects » Eclipse Platform » Bug in eclipse xerces parser - who can help?
Bug in eclipse xerces parser - who can help? [message #119689] Sat, 30 August 2003 05:29 Go to next message
Hi, I am not sure whether this is the right place to post this problem but
I didn't see any better forum.
I am using the xerces parser from eclipse 4.0.7 and encountered into a
problem with the XMLSerializer, which has also been reported to the apache
forums (bug 21404 - Elements that have long text as the text node content
are serialized with a line break and additional indentation).
I cannot use the proposed workaround by overriding the printText methods
since they have been declared as final in the eclipse version.
On the other hand I need to use the eclipse version because I am using the
property to set the external-schemalocation which is not working properly
with any of apache xerces 2.3.x+ releases that I have tried.
Is there any newer version of the eclipse xerces parser where this problem
has been fixed?
Where can I find the sources of the eclipse xerces to change the method
declaration and use the workaround .... are they included in the eclipse
sources?
Or can I use the XMLSerializer class from apache.org ... is this working
with the other eclipse xerces classes?
Thanks in advance for any help.
Michael
Re: Bug in eclipse xerces parser - who can help? [message #119803 is a reply to message #119689] Sat, 30 August 2003 23:32 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
You're kind of in a pickle. Eclipse uses out-of-date versions of Xerces
dropped off at random times from somebody in IBM (probably on the xml4j
team, but I've never confirmed that). Then, to make matters worse, Eclipse
uses its out-of-date Xerces in such a way that it interferes with all
plugins' use of Xerces. You can't even put your own version of Xerces in a
jar along with your plugin without writing your own classloader to load it.
There is an active bug on the subject, but that probably won't help you
anytime soon.
Good grief.
The current release of Xerces is 2.5.0. Tried that?
Bob
Re: Bug in eclipse xerces parser - who can help? [message #123432 is a reply to message #119803] Fri, 05 September 2003 16:35 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
I don't think it's quite that bad. You can't put a conflicting xerces
on the boot classpath or in your JRE's "ext" directory. I'm fairly sure
you can put your own private xerces in your plugin and load it in the
normal way without playing with class loaders though. The plan item to
remove the core platform's dependency on xerces should address these
problems:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37696
> anytime soon.
Re: Bug in eclipse xerces parser - who can help? [message #123546 is a reply to message #123432] Sat, 06 September 2003 01:06 Go to previous message
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
news:3F58F3AB.7020309@oti.com_...
I'm fairly sure you can't.
> The plan item to
> problems:
I keep hoping. It's not obvious from the comments on the bug, or from your
comment just now, that we all agree on what the problem is. :-(
Bob
Eclipse
a
it.
> > anytime soon.
Previous Topic:Save as don'work in M3
Next Topic:Export feature wizard deletes my own build.xml file
Current Time: Wed Nov 19 10:15:58 EST 2025
Powered by FUDForum. Page generated in 0.09282 seconds
