Home » Archived » BIRT » How to get Data from datasource in header and footer
How to get Data from datasource in header and footer [message #119651] Mon, 30 January 2006 05:22 Go to next message
Originally posted by: xxx.xxx.com
Hi all,
Can you tell me how can i get data from datasource in header &/or footer.
Header and footer are generate before my datasource are populate. So when
i try to use row["...."] in header or footer, i've nothink :(. The same
think if i try to use javascript var (it's populate too late). the only
var i can get, it's "params"....
any idea to write data in header/footer ?
regards.
Denis.
Re: How to get Data from datasource in header and footer [message #119706 is a reply to message #119651] Mon, 30 January 2006 06:13 Go to previous message
got it. I use method initialize() to declare a global variable with data
from my objectdatasource. (i didn't find this method before)
Denis.
Previous Topic:2.0 RC2 bug
Next Topic:URGENT: API Docs
Current Time: Sun Jul 13 22:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.06718 seconds
