How to compare a file with the history? [message #10919] |
Tue, 21 July 2009 12:55  |
I'm trying to compare the file in my working tree with some entry in the
history (Resource History)
For most other version control plusgins I can do this with the Compare
With. Egit provides only comparision with the Git Index.
Also, there are few context menu options in Resource History (like "set as
quickdiff baseline") but I do not know what it means (perhaps because I'm
new to Git).
Dmitry
Re: How to compare a file with the history? [message #10947 is a reply to message #10919] |
Tue, 21 July 2009 19:35  |
Yes, the compare with Resource History feature is missing from EGit
currently. So only the comparison to the index is offered.
> as quickdiff baseline") but I do not know what it means (perhaps because
> I'm new to Git).
The quickdiff viewer shows a ruler down the margin of a text editor
indicating which lines differ from some base revision. Typically this
is used to show what you have modified in this file, but have not yet
committed. That menu option lets you select something other than HEAD.
You need to enable Git as the quickdiff provider in the workspace
preferences for this to work, and sadly only one quickdiff provider can
be enabled per workspace, so if you use both CVS and Git projects in the
same workspace you are forced to pick only one quickdiff provider for
all files.
Re: How to compare a file with the history? [message #573645 is a reply to message #10919] |
> I'm new to Git).
all files.
FUDForum. Page generated in 0.05902 seconds
